Wanting: All 4 power windows to go auto down and auto up at same time with the push of the lock window button. Is this possible and if so how can it be done. Basically I want to be use the "lock all windows button" to be able to auto raise or lower all 4 windows when i hit the switch like the drivers side already does. Here is the link to where you can download the electrical manule for the 05 Scion xB which i am trying to do this on. Once folder is opened its the one that shows the layout of the wire is 086-089 power window.pdf if anyone is able to help me plz it would be much appricated. I'm looking over this wire diagram and i just cant figure it out. So please use small easy words to explain how this can be done. thank you all! If anyone knows a way for me to post the pdf file on here so you dont have to download it or use the links post that up here also and ill do that instead.
web site of artical i posted about it:
http://www.scionlife.com/forums/view...455&highlight=
link for the manule to look at the wire electrical manule:
http://www.scionlife.com/forums/viewtopic.php?t=138456
www.scionlife.com/tech/electrical/electrical_xb05.zip
