Old 09-14-2011, 05:18 PM   #1
Cletis's Avatar
Default POCO Transformer Sizing
What factors do the engineers from POCO use to determine if residents need new transformer?
Ex. I have a house we put a 25kva on demand heater in and when it kicks in the whole house dims. Turns out that 7 houses are on a 50kva transformer. The tech said he will talk to his boss to see if they can upsize it.
Cletis is online now   Reply With Quote
Old 09-14-2011, 05:26 PM   #2
PGW Professional
Magnettica's Avatar
Did you upgrade the service? A 25 kw load is a significant load that the POCO I'm sure wants to know about. Perhaps your inspector can answer your questions since he's the one sending in cut-in cards. That's probably what I would do is call the local EI.
Old 09-14-2011, 05:27 PM   #3
BBQ
BBQ's Avatar
My guess is, when it fails or when it cannot supply the voltage that is required by the local rules.
BBQ is online now   Reply With Quote
Old 09-14-2011, 05:29 PM   #4
BBQ
BBQ's Avatar
One other thing, before you get the power company involved you might want to look at their terms of service and find out if they require being notified before a 25 KW load was added.
Old 09-14-2011, 05:30 PM   #5
BBQ
BBQ's Avatar
Yeah, that dawned on me as well, that is 104 amps at 240 volts.
Old 09-14-2011, 05:35 PM   #6
Cletis's Avatar
Default upgrade
Yeah. It's all legit. Did a 150-200 amp upgrade with added circuits and a load calc (RCO). It passed and that is when the POCO tech came out and looked at service. I've notice around here they tend not to do things until they blow up or get enough complaints. I know it technically needs to be upsized I"m sure of,but, if they do that's another story.
Old 09-14-2011, 05:59 PM   #7
randas's Avatar
I just did my first tankless.. 80A at 240. Walked down the street and there are 6 houses on a 15kva...
randas is offline   Reply With Quote
Old 09-14-2011, 06:44 PM   #8
If the houses are all Electric in the area I see that transformer failing very prematurely. Hopefully its fused right and wont go out with a bang.
If diming is a problem the house should have its own 25-50kva unit. File a complaint with poco.
Old 09-14-2011, 07:01 PM   #9
PGW Professional
Magnettica's Avatar
This is an issue going forward all over the country. From what I understand is that if an upgrade past 200 amps is in order then the POCO needs to know about the added load. That's a PSEG requirement. I'd imagine that other poco's have similar rules and regulations.
Poco in my way... jwjrw General Electrical Discussion 11 05-13-2011 01:42 PM
POCO vs. NEC InPhase277 Services and Service Equipment 4 04-04-2011 10:53 AM
What would Poco do? RIVETER General Electrical Discussion 1 07-19-2010 04:36 AM
How to PO a POCO John Code Violation Discussion 3 12-23-2008 11:44 PM
transformer sizing ???? Vr_ecobox Services and Service Equipment 1 12-07-2007 07:49 PM
