Old 03-22-2011, 08:46 PM   #1
Bababoee
captkirk's Avatar
Default Pool bonding certification.?
Do public Hot Tubs and pools have to get certified every so often..? I am looking at doing some bonding work on a commercial building and the inspector is telling me that I need to do an ohm test on all the bonding points..? He says I need to be under 25 ohms for each point of bonding..? Is this SOP..?
Full time Bovine Scatologist.
Old 03-22-2011, 08:57 PM   #2
Bkessler's Avatar
If it is it should be in writing somewhere.
When ls lunch?
Old 03-22-2011, 09:01 PM   #3
Bababoee
captkirk's Avatar
ive been looking..
Old 03-22-2011, 09:03 PM   #4
Bababoee
captkirk's Avatar
Has any NJ electrician had to do this..? What is needed for the test..? I have never done one and thought someone might have ..?
Old 03-22-2011, 09:09 PM   #5
PGW Professional
Magnettica's Avatar
Ever see an inspector actually test your ground rods? I haven't. Someone will have an answer. The tool is very expensive too from what I understand.
Old 03-22-2011, 09:11 PM   #6
Bababoee
captkirk's Avatar
OK found the certificates and info about it....now what test....what point do I use as the referance..? Motor lug plus point being tested..like pool filler pipe or ladder..? or do I need a "real" ohm meter.?
Old 03-22-2011, 10:01 PM   #7
Bababoee
captkirk's Avatar
never mind, i found all that I needed in MH...thanks ...
Old 03-22-2011, 10:11 PM   #8
There is no reason to test them, it doesn't matter what the test produces if you install 2 rods.
If you install 1 rod, the inspector will probably want to test them, in which YOU have to supply the equipment for the FOP test.
RobTownfold64 is offline   Reply With Quote
Old 03-22-2011, 10:14 PM   #9
Bababoee
captkirk's Avatar
yea but thats a grounding....bonding test is just checking that the ohms is low.....am i wrong..?
Old 03-22-2011, 10:20 PM   #10
We have pool inspections here, but they are worthless. Many EC's use a DMM to measure ground resistance. I think it was a good idea MAYBE, but nobody knows how to implement the inspections properly.
Brian John
Leesburg, VA
Old 03-22-2011, 10:24 PM   #11
PGW Professional
Magnettica's Avatar
Old 03-22-2011, 10:25 PM   #12
Chairman of the Bored
BuzzKill's Avatar
good article recently in ECM about the whole pool bonding/grounding fight over the '08 to '11 wording regarding such.
I'd rather be sleeping.
Old 03-22-2011, 10:25 PM   #13
PGW Professional
Magnettica's Avatar
Got a link?
Old 03-22-2011, 10:30 PM   #14
BuzzKill's Avatar
Got a link?
I get the hard copy for free in the mail but I imagine you could find it in last month's issue online; the article is basically an argument over two grounding installation methods: wire mesh surrounding the pool vs. a single #6 wire buried below the decking.
The Following User Says Thank You to BuzzKill For This Useful Post:
Magnettica (03-23-2011)
Old 03-22-2011, 10:41 PM   #15
Bababoee
captkirk's Avatar
yea im presently looking through my stash that my wife was nice enough to put in the basement.....
Pool BOnding Mark Turner General Electrical Discussion 4 12-28-2010 05:09 PM
Pool Bonding dawgs NEC Code Forum 8 07-20-2009 07:30 AM
Pool Bonding rebel34 NEC Code Forum 21 08-16-2008 09:32 PM
Pool water bonding Joe Mush Tools, Equipment and New Products 8 06-08-2008 11:49 AM
Pool Bonding preacher NEC Code Forum 15 03-29-2008 11:10 AM
