P (power watts) = E (volts) x I (amps)
3.7 v x 9 a = 33.3 watts
Your source is not the determining factor, you need to know the HEATER load either in watts or amps.
I would NOT use a potentiometer for this application. You might want to look a a solid state switch, and then TPO time-proportion-output in percent to reduce the heating.
Example TPO period is 2 seconds max.
If you want to reduce heater output, set the TPO to 50%. 1 sec on / 1 sec off. Or 25% TPO 0.5 sec on 1.5 sec off
Google "solid state heater power controls"
