Old 07-30-2008, 07:37 PM   #1
kawaikfx400's Avatar
Default pressure switch
So im still a new guy here in the electricial field, only been in 10 months but, a buddy of mine has an air compressor with a pressure switch. Its 240 into the motor,then it has a whip off of it to the pressure switch off the tank to shut it down when it reaches operatering pressure. But its not shutting down so i took off the switch. Replace it? And i dont understand how its 240 into the motor from the plug, then a whip to the switch. How does the switch tell it to shut off the motor? Is is low voltage sending back to the motor? and it was only 2 wires on one side of the pressure switch. I've wired some wells with the boss with these switches before, just never an air compressor.
kawaikfx400 is offline   Reply With Quote
Old 07-30-2008, 07:50 PM   #2
"A" inside wireman
randomkiller's Avatar
The pressure switch is just breaking one leg of the 240v, just like switches in many appliances, one side is often hot.
"One Nation Under God"
Old 07-30-2008, 07:54 PM   #3
So it was wired correctly then? Being just 2 wires from the motor down thru some carflex into the pressure switch and landing on one side of the switch? I'm just trying to make sure everything was wired correctly before i purchase a new switch. Im asking the boss in the morning about this but im just confused right now and its driving me crazy.
Old 07-30-2008, 11:56 PM   #4
It's very common, and completely legal to break only one leg of a 240 volt circuit like this. Almost all stoves and ranges do so, and heater thermostats that are wall mounted and two pole only break one leg unless they're turned all the way off.
As a side note, it's also legal, but not as common, to break 2 legs of a 3 phase motor circuit for control of the motor.
Rob
Old 07-31-2008, 06:13 AM   #5
"A" inside wireman
Rob
I see that all to often in cheap a/c equipment for the compressor circuits.
Old 08-02-2008, 02:31 PM   #6
on another note, What would make a pressure switch not work? Can i adjust it at all? Doesnt seem like theres much to it.
Old 08-02-2008, 04:53 PM   #7
"A" inside wireman
If there are holes in the diaphram from moisture in the air the switch will not make. Some are and some are not adjustable.
Looking for switch Hefty General Electrical Discussion 2 10-21-2008 11:15 PM
Replace a 2 way switch by time lag switch emleray General Electrical Discussion 4 09-12-2008 04:18 PM
Hot 3 way switch subelect General Electrical Discussion 21 07-20-2008 09:46 AM
Bolted Pressure Switch brian john General Electrical Discussion 9 06-09-2008 09:09 PM
Bolted pressure Switch brian john General Electrical Discussion 5 07-11-2007 09:18 PM
