Old 09-05-2008, 04:20 PM   #1
Default PVC MC cable in pvc conduit under slab?
Can PVC coated MC cable be installed in pvc conduit under a concrete slab. I want to connect multible 12"x12"x6" floor boxes together that have a recp. box in the floor box. Kind of a box in a box set up. The larger box is for an compressed air line and L.V. cables. The recp. will be in an 4"x4" JB.
I will use pvc coated MC for wet location.
nealla is offline   Reply With Quote
Old 09-05-2008, 04:33 PM   #2
Bkessler's Avatar
I hope so, I did it about ten years ago to reach the chairs for dentist office.
When ls lunch
Old 09-05-2008, 06:10 PM   #3
semi-electrician
It depends on the location, you can't do that in NY.
Old 09-05-2008, 07:39 PM   #4
If by PVC coated MC cable you mean TEK cable (I'm pretty sure it is), I don't know how many thousands of feet of it I've pulled into conduit at power plants. All sizes, from small control cable to big stuff, 750 MCM 15 KV. Many times multiple cables in one conduit. No inspector has ever questioned it so far.
It's very common to go from a cable tray down to PVC conduit under a road or something, then back up into the tray again. It's just as common to go from a cable tray down underground to a transformer or switchgear in conduit.
It doesn't pull very easy dry, soap helps a lot.
Rob
Old 09-05-2008, 10:23 PM   #5
Thanks for the info.
I also know it as garage decking mc.
Old 09-05-2008, 10:25 PM   #6
A dentist office is what I'm using for.
Old 09-05-2008, 10:28 PM   #7
Bkessler's Avatar
Yeah you kind of need mc for that since you have know way of knowing how it's going to hook to the chairs. YOu could use flex but there is not enough room to negotiate with.
When ls lunch
Old 09-05-2008, 11:02 PM   #8
It is going to terminate in a recp box in the floor. It is a demo area for sales of dentist equipment. I'm going to use a weather tight box for the recp.
Old 09-05-2008, 11:06 PM   #9
Bkessler's Avatar
well that was certainly presumptuous of me.
When ls lunch
Old 09-06-2008, 06:43 AM   #10
just wondering, what kind of fitting will you use once the mc is in the junction box or is that the box in a box thing you were referring to, and is the sheath on your mc rated as a ground, im thinking hospital grade mc with the redundant ground might be a better choice but if its just a demo then no biggy
racerjim0 is offline   Reply With Quote
Old 09-06-2008, 03:36 PM   #11
nap
a real PITA
You state it is a demo unit. Does that mean it is not going to be fully funtional as a dentist chair and used? If not, ou need to be careful using MC in this app. Med treatment facilities have some special rules and there is only 1 MC cable that fits this bill (Southwire MC AP).
AC cable is acceptable in these locations but until the recent intro of Southwires MC AP, no MC cable was listed for use in a patient treatment area.
Old 09-06-2008, 04:12 PM   #12
Bkessler's Avatar
I always say MC even when I am using AC the stuff I used ten ten years ago was the green ac cable with the extra ground. Although I remember thinking that the green paint would impede the ground. I actually have never seen pvc coated mc.
When ls lunch
Old 09-06-2008, 04:40 PM   #13
nap
a real PITA
I have fun with the AC/MC thing when working a med job. Somebody will say go grab that MC. I'll come back empty handed and they ask where is the MC. I tell them I couldn;'t find any in all those rolls of AC cable. Then they want to argue that it's MC so I go get a tag and show them it's AC. Just my way of being a **** at work once in awhile
Old 09-07-2008, 10:40 AM   #14
all I know is that the manufacturers sure are proud of that little aluminum wire, it raises the price of a roll $110
Old 09-07-2008, 11:39 AM   #15
nap
a real PITA
is the TO $110 or ADDS $110?
It has to be ADDS $110.
WOW!! You ain't kidding there.
I am going to have to go price shopping. I have never really compared the price of AC to MC or this new MC AP stuff. Curious to see how it all compares.
Until this MC AP stuff, there was no alternative to AC but presumably it is more expensive than MC since that is what is used everywhere except where AC is required to meet codes.
Old 09-08-2008, 05:55 PM   #16
No it is for a demo area only. It is a dentist supply shop, no medical care.
It is not functional for use just demo .
Old 09-09-2008, 12:55 AM   #17
nap
a real PITA
then I do not believe MC AP or AC would be required. You might want to talk with the inspector to be sure before installing anything though.
Old 09-09-2008, 03:27 PM   #18
Thanks to everyones input,. Great site for help!
Conduit for UPS bman4523 Code Violation Discussion 7 02-05-2009 12:08 PM
slab construction requirements rebel34 General Electrical Discussion 4 01-27-2008 07:47 AM
Underground work and slab on grade MDShunk NEC Code Forum 4 01-28-2007 08:38 PM
