Question about Journeymans Test and formulas used - Electrician Talk - Professional Electrical Contractors Forum
Old 06-10-2010, 02:30 AM   #1
Golden Arc's Avatar
Rewards Points: 160
Default Question about Journeymans Test and formulas used
I was told that these book are what im allowed to use on the Journeyman's test and that you're are not allowed to have formula notes. My question is does any of these books like maybe the NEC Handbook have formulas in them? If not thats like 100's of formulas im going to have to memorize.
allowed books
NFPA 70 - National Electrical Code, 2005, National Fire
Protection Association (NFPA), (800) 344-3555,
www.nfpa.org, ISBN 0877656231
Code of Federal Regulations - 29 CFR Part 1926 Revised as
of 2008 (OSHA), Superintendent of Documents, (888) 293-
-OR- Code of Federal Regulations - 29
CFR Part 1926 Selections as of 2008 by PSI, (800) 733-9267,
(See order form at the end of this bulletin.)
NFPA 70E - Standard for Electrical Safety in the
Workplace
, 2004, National Fire Protection Association
(NFPA), (800) 344-3555, www.nfpa.org
National Electrical Code (NEC) Handbook, 2005, National
Fire Protection Association (NFPA), (800) 344-3555,
www.nfpa.org, ISBN 0877656258
Golden Arc is offline   Reply With Quote
Old 06-10-2010, 02:41 AM   #2
Infiltrator
Widestance_Politics's Avatar
Rewards Points: 608
allowed books
Workplace
The NEC Handbook is full of examples, explanations, and formulas.....
Widestance_Politics is offline   Reply With Quote
Old 06-10-2010, 04:18 AM   #3
Rewards Points: 150
They let you bring in the handbook? Wow
Geoff C is offline   Reply With Quote
Old 06-10-2010, 10:20 AM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 368
100's of forumulas ? you gotta be kidding. there's only 4 that I can think of that you need to know
ohms law E=IR
resistors in parallel Rt=1/(1/r1+1/r2...)
voltage drop vd=2kil/kcmil
power =VA
and using 1.73 when necessary
Old 06-10-2010, 12:18 PM   #5
Fried Bologna um um good!
jwjrw's Avatar
All we got to use was the nec and they supplied it. You could not bring anything but a pencil or two.
Old 06-10-2010, 12:42 PM   #6
william1978's Avatar
Rewards Points: 2,000
When I took the journeyman's test all I was allowed to bring was a photo ID everything else was provided code book, calculator, pencil, scrap paper and you would not get your test results unless you turned the scrap paper.
Old 06-10-2010, 12:53 PM   #7
jwjrw's Avatar
Yep I had forgot about that. But they did let us bring our own pencils. I had forgot my id so Angela had to go ask the cheif if I could start and have someone bring it to me. He knew me so he said "you can this time"
Hell I didn't plan on taking it but once anyway. I passed the first try.
Old 06-11-2010, 03:21 AM   #8
Golden Arc's Avatar
Rewards Points: 160
ohms law E=IR
power =VA
And Xc, Xl, It, Ic, Ir, P, PF, Ec, Er,Z, VarsC and etc.
So at least some of these are in the handbook for sure?
Old 06-13-2010, 01:47 AM   #9
Golden Arc's Avatar
Rewards Points: 160
Can anybody else confirm that there are formulas in the handbook?
Old 06-14-2010, 01:32 AM   #10
Rewards Points: 150
It's still the same way, at least a month ago. Actually, I wasn't even allowed pens or even my wallet. They provided a dry erase board and markers for calculations. Or are you talking about some sort of jman exam seperate from the one from the NCBEEC?
OP, there are sample calculations in the back of the code book, if those are what you are asking for. Not formulas per se, but sample range calculations.
millerdrr is offline   Reply With Quote
Old 06-14-2010, 04:53 AM   #11
Golden Arc's Avatar
Rewards Points: 160
I looked at the examples in the back of the Code book but i didnt see any specifically for finding Xl, Xt, Xc, Z, P, etc.
Old 06-14-2010, 01:49 PM   #12
Rewards Points: 772
Man, things have changed since I tested. I took my Masters first. Never took a journeyman's test ever.
8 hours, Tom Henry reminders nicely inserted into my three ring binder code book, along with "Keyword Index", transformers and calculations books in my book bag, calculator with ohms law circle sticker on back. I never touched the stuff in the bag as I was afraid they would see me (450 people testing together, all crafts).
Without Tom Henry I doubt I would have passed on the first try.
In SC when I took the test, if you went through the contractors association you took the masters regardless if you had a JW or not. If you went through the municipal association you had to take both. Our instructor had everyone on the right page first class. He even had us pick a test date and all of us signed up, paid and had a test date picked before the third class. The ones that were not serious naturally left the class on day two.
OP......The things I spent the most time on were never asked in the exam. I was blind sided all day long. I took many educated guesses. Just remember to not leave any questions blank. If you guess, at least you have a chance of getting it right. I think I got lucky on several calculations.
Get plenty rest the night before and do not study too much that night. If you don't know it buy the last night you just don't know it. Good Luck!
What to study for Journeymans jculber General Electrical Discussion 13 04-17-2014 09:34 PM
Help With Test Question jhoward General Electrical Discussion 5 04-21-2010 05:58 PM
Here is a test question for you? sparks134 Services and Service Equipment 15 04-06-2010 01:49 AM
Question on the test Carmexx General Electrical Discussion 6 05-23-2009 09:49 PM
Test question mike2105 General Electrical Discussion 6 09-18-2007 10:14 PM
