Originally Posted by Carmexx
Thanks that really helps...
But heres another question, I know the right answer but I can't seem to figure out how they got the answer.
Q: Five loads are to be energized from a 240 V supply. Three of the loads require 12.6 V and two loads require 35 V each. All the loads require 225mA. Find the resistance of a suitable dropping resistor if the five loads operate in series.
The right answer is: 587.556 Ohms... But how did they get that answer?
I haven't worked the math, but I'll let you in on how it's done. First, total circuit resistance is 240/0.225 = ?
The current through each component of a series circuit is the same, in this case 0.225 A. You can figure the resistance of each load by using
R = E/I. So... 3(12.6/0.225) = ? And... 2(35/0.225) = ? Add them together, then subtract that from the total resistance to get the missing resistance.
