12-21-2007, 12:54 PM
questions from a novice
HI,
I am trying to determine the electrical costs of items in the house.
if someone could help me with the equation used, that would be great.
for instance the garage door opener is 120v and 6amps.
it takes 10 secs to open and 10 to close.
tks in advance
leewaytoo
ps. say you were re-wiring a home, what gauge wire would you use
from the svc panel, if price were not a concern, only concern is
to use less electricity?
tks again.
12-21-2007, 01:23 PM
Motor operating cost have many variables inrush, power factor during start up ect..
but for a 6 amp load at 120 VAC.
120X6=720 watts .720 kw
10 seconds is .00277 of an hour so at .09 cents a KWHR you have an extreme cost of .0001794 cents..
12-21-2007, 03:10 PM
Only 0.09 cents per Kw hour. Your getting your electricity cheap. Can you run a wire under the pond bed to my house over here,
12-21-2007, 03:38 PM
.09 cents in Virginia not sure about the rest of the country, more expensive as you head north. and of course there are the inevitable taxes.
12-21-2007, 05:13 PM
Don't you mean 9 cents? Right now we're at 10.86 cents/kwhr in Baltimore.
12-21-2007, 06:00 PM
TYPO sorry
12-21-2007, 06:58 PM
TYPO sorry
Wishful thinking...
12-21-2007, 07:23 PM
Electric cost
Here is Idaho our rate is .639 residential rate. good dams
You keep doin' what you're doin, you will keep gettin' what you got.
12-22-2007, 05:02 AM
.639 dam good
12-22-2007, 05:09 AM
here in london we pay 15.11p
12-22-2007, 09:51 AM
15.11 p about .30 cents? A KWHR....
12-22-2007, 10:15 AM
tks for the replies
tks for the replies gents.
here in waterford michigan it is .04531 cents for power supply energy,
.04284 cents for distribution
total .08815 per kwhr
then there is the power supply surcharge of $4.52
and delivery surcharge of $2.57
and sales tax $1.90
so our usage was 457 kwh and the total bill was $49.28
for the month of august.
so with the extra stuff it comes to $00.107833 per kwhr.
natural gas is $00.974047 per ccf plus a $9 customer charge.
for august last, we used 6ccf for hot water, tankless works for me.
for natural gas heat and water this month of dec we/two have
used 96ccf's as of yesterday.
tks again for your replies.
leewaytoo
12-22-2007, 03:31 PM
Think I pay 7 pennies per Kw hr. That's about 3.8 cents. per Kw hour.The first 100 units are a bit more at 15 pennies for my workshop. More you use. Cheaper it is.
But for the home we are on a fixed rate for electricity and gas of £950 - 00 per year through one company - all you can use. That's appx $1800 a year.House has to be limited to a three bedroom type and not more than 3500 square feet of living space. Excludes areas such as car ports, entrance halls, lofts, wardrobes etc.
12-22-2007, 04:20 PM
Brian,
I don't entirely understand.
I understand 120Vx6A=720 watts, divided by 1000=.720KW, and 10seconds is .00277 of an hour but the rest I don't follow.
Is 9 cents per KWHR = to using 1000watts for one hour? If so, how can .720KW = 9 cents?
12-22-2007, 04:45 PM
12-22-2007, 05:17 PM
This is what I do not understand.
12-22-2007, 06:23 PM
The basic equation to determine watts is voltage multiplied by amps. Most providers charge by the kilowatt/hour -- thousand watts per hour.
I don't know what you mean by your question about wire size. Service wire sizes are determined by service size (main breaker) which is determined by the load. The smallest branch circuit is generally 15 amps using #14 wire, then 20 amps using #12 wire, 30 amps using #10 wire and so on. Some jurisdictions require all residential wiring branch circuits be at least 20 amps.
12-22-2007, 07:32 PM
#18
(.00277hr*.72kw)*9cents/(kw*hr)=.01794 cents. His math was off by a factor of 100. It's not .09 cents. It's 9 cents. It would be $.09 if you want to do decimals.
12-22-2007, 08:54 PM
#19
did anyone calculate in the verry expensive light bulb that stays on 10 minutes after each opening and closing of the garage door.
Kris.
12-22-2007, 09:18 PM
#20
9 cents is .09 as a dollar is 1.00 and 9 cents is 9/100 of a dollar which makes 9 cents .09 mathematically. Now I am no math expert by any stretch of the imagination. So others can try and I will recalculate my calculations.
