Closed Thread
Old 09-30-2008, 01:21 AM   #1
mhl
Default Recommendation: AC lights off of Inverter, or DC rechargeable lights
I need to run 2x300 watt halogen lights ( or equivalent DC rechargeables like a floodlamp) for 2 hours with full output. Am I better off with 2 car batteries run thru an inverter for ac power, or am I better off just buying 2 rechargeable 12v from an autoshop. I can't run a generator. I've have no experience here so I'm looking for the best solution. Recommendations on your preferred set-up would be greatly appreciated.
mhl is offline
Old 09-30-2008, 01:44 AM   #2
I don't think that you will find a 12 volt 300watt rechargeable lamp which will run for 2 hours.
A 1000 watt modified square wave inverter should be able to handle that sort of load easily enough. You could use a couple of 50 Ah batteries but I would probably bo for a couple of 75 Ah truck batteries. If you are going to be doing this very often, get some good quality deep cycle batteries and a good switch mode charger.
AussieApprentice is offline
Old 09-30-2008, 01:59 AM   #3
mhl
From Australia! Thanks! Whats your choice for inverter/ Cheap is always good, and what features?
mhl is offline
Old 09-30-2008, 04:03 AM   #4
If all you want to do is run resistive loads such as these lights then a modified square wave (MSW) inverter from a reputable brand should be cheap and reliable.
Inductive loads such as motors, some transformers and lights with inductive ballasts should be run on pure sine wave inverters.
Some switch mode power supplies and dimmers have trouble with some MSW inverters as well.
Old 09-30-2008, 06:27 AM   #5
Thanks for posting on ElectricianTalk.com. The Moderators/Admin of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
As stated in the sign up page, ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at
www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Speedy Petey is offline
Closed Thread
Troubleshooting outside lights Roger123 General Electrical Discussion 18 02-25-2009 12:32 AM
Can lights in closet? k2x NEC Code Forum 27 12-21-2008 04:58 PM
LED lights frank General Electrical Discussion 10 08-27-2008 01:43 PM
How do I hook up 8 lights? Karl hurrell UK Electrical Forum 2 02-08-2008 04:37 PM
outside lights philip657 UK Electrical Forum 2 12-15-2007 05:37 PM
