Old 06-29-2008, 12:59 PM   #1
Default Replacing a NEMA L5-20P connector on a PDU
Hello All...
When ordering in a Power Distribution Unit (PDU, basically a big power bar) for one of my computer racks, I made a mistake and got one in with the L5-20P connector (or what I refer to as the 'plug that you twist in').
The UPS in this rack does not have this kind of plug in, rather what I call the 'standard' three-prong plug.
Is it possible to cut off/re-wire a standard 3-prong plug onto the same wiring in the PDU? If so, are there any specifics I need to follow (colour for ground wire, etc.)?
I will get an electrician to do it, with a high-quality plug, but I need to know if it is possible to do.
For reference, this is the PDU I have:
http://www.apc.com/resource/include/...ase_sku=AP9551
Thanks,
TN
TNorman is offline   Reply With Quote
Old 06-29-2008, 01:05 PM   #2
Yes.
bobelectric is online now   Reply With Quote
Old 06-29-2008, 02:39 PM   #3
JohnJ0906's Avatar
Certainly possible, but I am sure you will void the warranty.
John from Baltimore
"One day at a Time"
Old 06-29-2008, 03:44 PM   #4
"A" inside wireman
randomkiller's Avatar
Buy an adapter cord from Grainger.
"One Nation Under God"
Old 06-30-2008, 02:10 AM   #5
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Grainger will rip you off. Home depot, lowes, or any other store of the like will have the adapter you need.
~Matt
Old 06-30-2008, 05:56 AM   #6
"A" inside wireman
~Matt
I would just rather have an adapter made in the USA over one of those china made ones from the big box stores. Lowes may have a decent one but that "commercial electric" or other bogus stuff from the depot is crap, it just looks like it's made well, til you use it.
Old 06-30-2008, 08:12 AM   #7
Certaintly an electrician can safely swap those pesky L5 connectors for the ones you desire.
As to your APC warrenty, how much of a warrenty do you need for an item that you describe as "basically a big power bar". I know, in case of catastrophy, etc. Go ahead and have your favorite EC change the connectors.
As to using an adapter, you most likely do not need to introduce one more 'failure point' into your equipment chain. You cannot beat a twistlok, though.
As to "Grainger will rip you off", their venders are 'mostly' American, their products are better than most, their service is terriffic, and yes, they may be a little more spendy.
BTW, I have no connecion with Grainger, just have been a customer over the years.
Work'in For That Free Tee . . .
Be Safe Out there
Old 06-30-2008, 09:00 AM   #8
And Grainger's is next to my office I'll pick a few up on my way to your facility. travel and expense's extra OF COURSE>
Old 06-30-2008, 03:50 PM   #9
TNorman, I apologize for not looking at the APC AP9551 'PDU' that you purchased before I posted.
Men, it is only a 12 lf plugmold strip with an L5 connector on a whip. PDU?, I was thinking a real PDU, there I go thinkin' again
Be Safe Out there
Old 07-01-2008, 12:59 AM   #10
Noticed in the link that APC had a 2 year warrenty on it, changing the plug would prob. void it.
Norcal is offline   Reply With Quote
Old 07-01-2008, 01:03 AM   #11
Burger Flipper
TOOL_5150's Avatar
AFter I posted last time, I started thinking more about this. You should have your electrician change the receptacle to an L5-20R
If youre spending the money on this power bar, you probably want to keep your syatems up and running - so why not use a twist-lock plug and recep?
Just a thought....
~Matt
Old 07-01-2008, 11:01 AM   #12
Of course no one expects us to do 'sumpthin for nuttin'. Psst . . . they do not need to know our OH secrets!
Be Safe Out there
Old 01-27-2010, 04:02 PM   #13
Just a thought....
~Matt
I was looking for info on something else when I found this thread.
I'm pretty sure this is what he's looking for: NEMA locking plug adapters
Those will let you adapt from any combination of straight blade to locking or vice versa, as long as the voltage rating is the same. ie: L5-15 to 5-15, 5-30, L5-15 etc..but not L6-15, L6-30
ibx1227 is offline   Reply With Quote
Replacing Recessed Lighting Fixtures Reseman Lighting Design 6 09-28-2008 10:45 PM
Ideal Industries Brand New BNC Connector Aiken Colon Tools, Equipment and New Products 2 07-10-2008 09:42 PM
My apt. has a nema 6-30 R receptacle, what should I do john newman NEC Code Forum 3 09-21-2007 09:44 PM
Replacing electrical cords on tools Joe Tedesco Tools, Equipment and New Products 8 04-28-2007 11:05 AM
Post and find electrical jobs with NEMA MDShunk Business, Marketing, and Sales 0 02-14-2007 05:10 PM
