Replacing old Mag T12 with electronic Ballast - Electrician Talk - Professional Electrical Contractors Forum
Old 08-01-2012, 09:28 AM   #1
Default Replacing old Mag T12 with electronic Ballast
For single pin tombstones, the old connections have a white and black wire at one end. Do I connect the red from the ballast to the black and ignore the white wire (at the tombstone) while connecting the blue to the other end?
victormeg is offline   Reply With Quote
Old 08-01-2012, 09:34 AM   #2
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Wire it just as it is drawn on the ballast. You're going to have to do some rewiring to make it work. If I were you I'd rewire it and test it with lamps before putting the ballast cover back on. Good luck.
Replies based on NEC 2014
The Following 2 Users Say Thank You to Magnettica For This Useful Post:
green light (08-01-2012), victormeg (08-01-2012)
Old 08-01-2012, 09:37 AM   #3
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
No ,Look at the diagram on the ballast.
Are you an Electrician?
Old 08-01-2012, 09:46 AM   #4
Rewards Points: 432
Therese a Diagram?
JHFWIC is offline   Reply With Quote
Old 08-01-2012, 09:54 AM   #5
Diagram on Ballast only covers new connections. Shows to connect Hot & Neutral to ballast feed.
Old connections have a hot (Black) & Neutral (white) going to one end of the lamp.
Do I ignore the old connections of the neutral to the tombstones ( cap or disconnect them)
Old 08-01-2012, 10:00 AM   #6
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
Ignore old and rewire to new ballast requirements. It will have a picture and colors.
The Following User Says Thank You to nolabama For This Useful Post:
Old 08-01-2012, 10:03 AM   #7
crispy critter
green light's Avatar
Rewards Points: 1,024
Default sparky?
victor I gotta tell you at this point I dont think any one is gonna walk you through this step by step. The ballast has a diagram on it, a simple diagram at that, and if you are unable to read or follow it I doubt you are an electrician. Wire it as the diagram shows
I'm old enough to know better, but too young to care.
green light is offline   Reply With Quote
The Following 2 Users Say Thank You to green light For This Useful Post:
guest (08-01-2012), sbrn33 (08-01-2012)
Old 08-01-2012, 03:48 PM   #8
Nope, his profile says repair technician.
If he can't figure out something this simple I see some magic smoke release in his future.
Old 08-01-2012, 05:47 PM   #9
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
IF there's an equipment ground.
electronic ballast retrofit khfiei General Electrical Discussion 12 12-17-2011 06:45 PM
Electronic ballast user4818 General Electrical Discussion 15 09-17-2011 06:41 AM
Troubleshooting Electronic Ballast eutecticalloy General Electrical Discussion 25 03-19-2011 12:33 PM
T8 Conversion or T12 Electronic Ballast NolaTigaBait Lighting Design 19 05-12-2010 04:35 AM
Replacing 8, 2 lamp magnetic ballast lighting with electronic ballast and t8 lamps phish1985 General Electrical Discussion 4 03-02-2009 02:57 PM
