Old 06-18-2009, 11:08 AM   #1
Default residental service conductors in raceways
article 240 requires that secondary transformer conductors be protected in a raceway. I would like to see the same requirement for service conductors on a dwelling. A cable tv installer putting in a new line shorted out my neighbor's service and caused a fire by accidently drilling into the se cable, luckily the cable guy didn't get injured or killed and the house didn't burn down but the whole service needed to be replaced. I'm surprised that I don't see this happening more often, it doesn't take much effort to damage SE cable. Do you guys see this as a problem in your area? What are your thoughts?
I Conduit is offline   Reply With Quote
Old 06-18-2009, 12:51 PM   #2
I've seen it damaged several times,,,,,also it only last about 25 years in the sun. I always use conduit on ALL my services
mcclary's electrical is online now   Reply With Quote
Old 06-18-2009, 01:44 PM   #3
child please.....
NolaTigaBait's Avatar
no one around here uses SE for service entrance conductors...it's all done in conduit...it looks better and it seems to be a bit safer as well..
Old 06-18-2009, 01:48 PM   #4
You and me both.
It has never been allowed here. I couldn't believe it when I learned a couple years ago, via the internet, that this was still an acceptable practice. Accessible, unfused, unprotected wire/cable is stupid.
Old 06-18-2009, 02:01 PM   #5
child please.....
i didn't know this method was acceptable either until i saw it on the net...i was amazed to say the least
Old 06-18-2009, 02:39 PM   #6
They last longer than 25 years when a 90 degree or better sun isn't beating down on them 350 days a year. They're also typically protected by EMT sleeved over the SE cable for about 10'.
Old 06-18-2009, 05:06 PM   #7
child please.....
don't try to justify it
Old 06-18-2009, 06:29 PM   #8
I haven't seen anybody capable of using a tool accidentally zapping SE. It is always pretty darned obvious and it is supposed to be no more than five feet inside the structure (local requirement) now changed to "The least amount of SE possible" inside the structure. This usually means the meter socket and panel are back-to-back and not very accessible to accidental damage.
That said, I bet severely damaged SE would tend to disconnects itself by melting along with a lot of noise and commotion. Bet it got that guy's attention.
Old 06-18-2009, 06:41 PM   #9
Seen your member
Originally Posted by waco View Post
I haven't seen anybody capable of using a tool accidentally zapping SE. ...........
Old 06-18-2009, 06:44 PM   #10
child please.....
haha...leave it to 480 to post a pic...that isn't another one of your photoshops? we all know how you roll.
Old 06-18-2009, 06:46 PM   #11
Seen your member
Yes. It started out as a photo of a butterfly in Japan.
Old 06-18-2009, 06:48 PM   #12
Unlimited Lic.Electrician
william1978's Avatar
What about the other 15 days of the year.
Old 06-18-2009, 06:51 PM   #13
child please.....
shhhhhhhh...you are going to make lawnmowerman angry.
Old 06-18-2009, 06:54 PM   #14
Seen your member
I go on vacation, so they don't count.
Old 06-18-2009, 07:00 PM   #15
Old 06-18-2009, 07:00 PM   #16
Is that PeterD in the camper?
Old 06-18-2009, 07:04 PM   #17
child please.....
yeah, it's the Hack world tour starring 480sparky and Peter D
Old 06-18-2009, 07:05 PM   #18
Old 06-18-2009, 07:20 PM   #19
JohnJ0906's Avatar
John from Baltimore
"One day at a Time"
Old 06-18-2009, 07:32 PM   #20
Not Peter D
Originally Posted by 220/221 View Post
You and me both.
I don't understand why this is such a big deal to you when there are millions of homes with service cable that never have a single problem with it. Just because some bonehead cable TV installer doesn't check before he drills is not reason to condemn a wiring method. That same drill bit would have gone right through PVC too, by the way.
service conductors searay2006 NEC Code Forum 28 12-17-2009 03:11 PM
How many conductors? Adirondacker General Electrical Discussion 17 06-04-2009 09:20 PM
# of conductors in a box michaeljr7249 NEC Code Forum 4 08-07-2008 06:59 AM
Service Entrance Conductors Absolutetruthz Services and Service Equipment 15 06-08-2008 03:16 PM
230.53 Raceways to Drain Joe Tedesco NEC Code Forum 2 04-20-2007 04:59 PM
