reverse feed transformer - Electrician Talk - Professional Electrical Contractors Forum
Old 06-22-2011, 04:04 PM   #1
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
Default reverse feed transformer
Can you feed a transformer with 240 3 phase on the secondary and get 480/277 out of the primary?...In other words use it as a step up transformer, even though it's a step-down transformer...
REMOVED
Old 06-22-2011, 04:06 PM   #2
BBQ
Salty Member
BBQ's Avatar
Unlikely you can get 277 out of it but yes on the 480.
The high voltage side of it will likely be delta and not have a 'HO' terminal for the neutral.
Old 06-22-2011, 04:07 PM   #3
Hippie's Avatar
Rewards Points: 548
Yeah. Not sure about code though
Hippie is offline   Reply With Quote
Old 06-22-2011, 04:08 PM   #4
child please.....
Rewards Points: 14
Ahhh thats right...THanks Bob.
REMOVED
Old 06-22-2011, 04:19 PM   #5
Rewards Points: 2,002
They do make transformers for this application.
Old 06-22-2011, 04:20 PM   #6
child please.....
Rewards Points: 14
I assumed that, it was a curiosity question. I saw this at a job and was curious why they would do it.
REMOVED
Old 06-22-2011, 04:29 PM   #7
Rewards Points: 1,006
Generally it's a bad idea.
1. No neutral in most cases, unless the primary happened to have a center tap.
2. Inrush current can be excessive, and cause OCP trips at startup.
3. In the event of a catastrophic failure, very large fault currents can be generated.
4. Wrong (low) voltage. All transformers will have some voltage drop caused by winding resistance at full load.. The engineers design the transformer to produce the desired voltage by compensating. Backfeeding will cause the compensated winding voltage drop, plus additional voltage drop. So your output could be 10% below what you expect at full load.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 06-22-2011, 05:33 PM   #8
Rewards Points: 586
4. Wrong (low) voltage. All transformers will have some voltage drop caused by winding resistance at full load.. The engineers design the transformer to produce the desired voltage by compensating. Back feeding will cause the compensated winding voltage drop, plus additional voltage drop. So your output could be 10% below what you expect at full load.
Typically we see that issue on small transformers (though I cannot give a precise size range). With larger transformers all the other issues you mentioned, plus it messes up the the thought process for about 97% of the electricians that run into a transformer with a grounded delta or ungrounded delta.
Old 06-22-2011, 05:49 PM   #9
BBQ
Salty Member
BBQ's Avatar
OTH I have done it myself, have seen it done by others in the compaines I have worked for and come across it done by strangers and in each case it was working fine.
Square Ds position is it is not recommended (they would rather sell another trans) but not prohibited.
Old 06-22-2011, 06:08 PM   #10
220/221's Avatar
Rewards Points: 3,546
I did it years ago (not my idea/design) to feed a huge Ac unit the size of a trailer. They ordered 480 and only had 208 on the property. Their solution was a transformer running 24/7 even though the church was only occupied generally on Sundays.
The company the built the transformer told me it works either way but, If I wanted a label stating 208 to 480, it would cost an extra $300 or so.
I paid for the label and the transformer only lasted a year. They sent a replacement....with the 480 to 208 label . They swore to me that it was the same exact unit.
Old 06-22-2011, 06:28 PM   #11
child please.....
Rewards Points: 14
Lol...It all about the dollars...
REMOVED
Old 06-22-2011, 06:29 PM   #12
conduit dude
azsly1's Avatar
Rewards Points: 252
i've done that for some domestic water pumps in a high rise. they got new pump skids with 480 motors and only had a 240 service. worked well.
azsly1 is offline   Reply With Quote
Old 06-22-2011, 07:13 PM   #13
Smoke's Avatar
Rewards Points: 250
i got a call a few years ago from a coworker on a job where they tried to do it as temp for something (i forget what). they failed to realize the input/output amps would be reversed and toasted the xfmr
there's some technical crap to mull over
Smoke is offline   Reply With Quote
Old 06-22-2011, 07:36 PM   #14
Jlarson's Avatar
Rewards Points: 2,758
It's very common for me too.
Sent from my Droid
Jlarson is online now   Reply With Quote
Old 06-22-2011, 07:42 PM   #15
Chris Kennedy's Avatar
Rewards Points: 2,000
Used to be, now Siemens and SqD I know both have 45 and 75 kva 208Delta 480y/277 tranny at the same price as the 480Delta 208y/120's.
Bulldozers and Dirt
Reverse Wiring 480 Delta X 208 Y lectricboy General Electrical Discussion 9 11-04-2010 06:05 AM
Reverse power? danross Residential Electrical Forum 1 02-26-2010 05:00 PM
transformer in reverse billydnewjersey General Electrical Discussion 20 01-30-2010 11:09 AM
reverse fead transformer trip breaker chasey95 General Electrical Discussion 16 11-06-2009 09:18 PM
transformer reverse wiring challenge electric Services and Service Equipment 1 10-10-2007 06:48 PM
