Romex jacket color codes - Electrician Talk - Professional Electrical Contractors Forum
Old 01-14-2007, 02:03 PM   #1
Rewards Points: 3,855
Default Romex jacket color codes
Type NM-B cable first began to be manufactured with color-coded jackets in 2001 to aid in identification of the conductor size. The color code that was introduced, which continues to be used today is as follows:
14 AWG – White
12 AWG – Yellow
10 AWG – Orange
8 AWG – Black
6 AWG – Black
This color coding system was developed to aid those who sell, install, and inspect Type NM-B cable so that the cable size can easily be identified, to reduce mistakes resulting from the use of an incorrect conductor size.
It should be noted that this color coding system is not a requirement of NFPA 70, National Electrical Code® (NEC®) or UL 719, Safety Standard for Nonmetallic-Sheathed Cable. Type NM-B can be produced and sold without using this color code. As such, the print legend, which is required by the NEC®, should be used to verify the conductor size.
Extracted from NEMA Bulletin 94
Old 01-23-2007, 08:06 PM   #2
sparkysteve's Avatar
We still get some #10 spools that are still white from the company warehouse or the supply house. Most inspectors don't seem to care.
sparkysteve is offline   Reply With Quote
Old 05-16-2007, 10:41 PM   #3
Rewards Points: 1,464
On my way to a job wiring switches, I grabbed a 1/2 roll of 12/3,(white ).Used it anyway for 3 ways.(15 amp lighting)
Old 05-17-2007, 06:30 AM   #4
Mountain Electrician's Avatar
Rewards Points: 238
I was out of residential for about 15 years, and the color coded romex was one of the changes I really liked, along with the fact that the wire is smaller and easier to work with.
Old 05-17-2007, 08:15 AM   #5
Speedy Petey's Avatar
Rewards Points: 1,620
They really have no choice but to not care. As Marc stated, there is no code to enforce with regard to this.
Old 12-07-2008, 12:34 AM   #6
Hillbilly Deluxe's Avatar
Exclamation Color coding
Well, I have noticed that you can buy (only in bulk, 200 ft or more) 14, 12, 10, 8, or 6 ga wire in black or white at Platt Electric.
Hillbilly Deluxe is offline   Reply With Quote
Old 12-07-2008, 12:50 AM   #7
village idiot
piette's Avatar
Rewards Points: 330
Anybody else noticed the color coded wire seems to be causing a rash of helpers that seem to not care what size the wire is or even about how to properly identify what it is?
"What wire should I pull over here, white or yellow?"
"Number 12"
"huh? white or yellow?"
"nevermind, yellow............"
Jeff
piette is offline   Reply With Quote
Old 12-07-2008, 01:14 AM   #8
Bkessler's Avatar
Rewards Points: 2,000
Is there supposed to be color coding on type mc cable as well?
When ls lunch?
Old 12-07-2008, 01:46 AM   #9
cdnelectrician's Avatar
Rewards Points: 1,018
In Ontario we also have blue 14/2 romex which is to be used for arc fault protected circuits in bedrooms
Old 12-07-2008, 01:51 AM   #10
Semi-Retired
BryanMD's Avatar
Dunno 'bout supposed to but there usually is.
An inked band with colors on the outside of the jacket every 6 feet or so (convenient eh?)
Back to the OT it is like purple pvc primer.(say that 3 times) You can get it clear but when that is what the plg inspector is looking for, why make life harder. Dunno if that is plg code or not tho.
November 2011: Relocated to Winston-Salem.
May have to change the username suffix.
Old 12-07-2008, 09:01 AM   #11
Now that,I like.
Old 12-07-2008, 09:48 AM   #12
Rewards Points: 1,000
Is it just me or is the yellow NMC (12-2) harder to pull? Seems like the sheath is "gummier" than the old white.
Old 12-07-2008, 01:23 PM   #13
Rewards Points: 652
14 AWG – White
12 AWG – Yellow
10 AWG – Orange
8 AWG – Black
6 AWG – Black
Okay.
Old 12-07-2008, 01:42 PM   #14
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by John Valdes View Post
Okay.
If it cannot be produced or sold without those colors, it sure can be installed.
A long time ago, I started using about 3-4 feet of 12-3 between the disposal switch and the recep so I could have a split-wired recep under the sink. I did this so one half the duplex would be hot all the time for a future hot-water dispenser. I went out and bought several rolls of 12-3 at a time when it was still white. I still have 4 full rolls and the better part of another roll still sitting in the shop.
I also still have some 10-2 and 10-3 that is white.... just waiting to get used up. I've installed some for ACs and dryers, and the inspector dinged me for it until I showed him the jacket markings.
Old 12-07-2008, 02:35 PM   #15
Semi-Retired
BryanMD's Avatar
A long time ago, I started using about 3-4 feet of 12-3 between the disposal switch and the recep... I went out and bought several rolls of 12-3 at a time when it was still white. I still have 4 full rolls and the better part of another roll still sitting in the shop.
Do you pull individual 12-2's for the SABC's? Using 12-3 would sure burn up those rolls before too long.
Old 12-07-2008, 03:24 PM   #16
Absolutely. I just use the 12-3 between the disposal switch and duplex. Black is hot, red gets switched.
Old 12-07-2008, 06:51 PM   #17
village idiot
piette's Avatar
Rewards Points: 330
Have you checked the expiration date on that wire? It's probably well outdated by now and no good to use.
Jeff
Old 12-07-2008, 07:19 PM   #18
personal's Avatar
Rewards Points: 25
Yes, I have had that happen. You buy from one supplier (Nexans) which sells in colors and apprentices go brain dead and cant tell 14 awg from 12 awg when you buy from the supplier that only sells white NMD. Colored wire is no different than anything automatic that save us from thinking.
personal is offline   Reply With Quote
Old 12-07-2008, 07:30 PM   #19
Jeff
Um, what expiriation date?
You mean you completely rewire houses every 10-15 years?
Old 12-07-2008, 08:40 PM   #20
village idiot
piette's Avatar
Rewards Points: 330
You saw the wink right?
Although that might be a way to keep regenerating business for ourselves, an expiration date for wire
Jeff
E-Codes - Municipal Codes on the Internet Speedy Petey Other Codes and Standards 1 10-28-2008 11:22 PM
wire color paul d. General Electrical Discussion 6 08-03-2008 11:55 PM
color codeing stillirnin General Electrical Discussion 17 07-06-2008 08:09 PM
Anyone use True Color conduit? R Electrician General Electrical Discussion 14 04-14-2008 12:42 AM
color code question goose134 UK Electrical Forum 16 12-21-2007 12:31 AM
