Old 09-04-2010, 05:23 PM   #1
PGW Professional
Magnettica's Avatar
Default Service call today
I had been to this persons house a week ago to repair the "power going on and off." I checked for line and load voltage at the meter and finally at the main breaker. Everything checked out normal and even the connection to the utility at the service head were crimps so I assumed it was on POCO's end. PSEG shows up, they check there connection at the x-former and they even re-crimp the connection at the service head. Everything is working ok.
I specifically asked the HO's if the breakers were ever in the tripped position.
"No, we just did what the poco told us to do, turn the breaker off and then back on again. After that it's fine but it keeps going off."
I go back there again and notice the 150 amp main is a little warm to say the least. Sure enough, these two little screws on the left that attach the MB to the bus were loose. I tighten them, wait around for a few and flirt with the lady for a little while, and the breaker's no longer heating up.
Surprised to see this happen on a Siemens panel since they are made so well.
Old 09-04-2010, 05:26 PM   #2
PGW Professional
Magnettica's Avatar
I'd also like to add.... the first time I was there the breaker wasn't tripped.
Today, while I was there it did trip.
Difficult to find a problem when everything's working.
Old 09-04-2010, 05:26 PM   #3
This is sarcasm right?
The Following 3 Users Say Thank You to Bob Badger For This Useful Post:
76nemo (09-04-2010), brian john (09-05-2010), Mr. Sparkle (09-04-2010)
Old 09-04-2010, 05:27 PM   #4
PGW Professional
Magnettica's Avatar
Siemens are well made I thought.
I know they're a part of the Murray family though
Old 09-04-2010, 05:47 PM   #5
B4T
ET Road Warrior
B4T's Avatar
Do we really want a panel to last (30) years without needing any kind of service?
Seems EVERYTHING breaks down in a few years and needs replacement... why should electrical products be any different?
We do make a nice living fixing these things, in case you forget..
Old 09-04-2010, 05:52 PM   #6
I void warranties
Jlarson's Avatar
That problem is the type of thing that would have shown up on a FOP test. That's pretty much my MO on a call like that, check the voltage drop across the breaker and the amp draw on each leg before I go and start tightening or looking for other problems that way I know I fixed the problem.
The best never stop learning.
The Following User Says Thank You to Jlarson For This Useful Post:
John Valdes (09-05-2010)
Old 09-04-2010, 06:21 PM   #7
Bkessler's Avatar
I agree, the first thing I do on any job is try and get in the panel to do an fop test. Especially because here in socal it's all zinsco and fpe and bulldogs.
When ls lunch?
Old 09-04-2010, 06:30 PM   #8
FOP? Fall of Potential? What kind of test is this and how do you run one?
Jupe Blue is offline   Reply With Quote
Old 09-04-2010, 06:42 PM   #9
Licensed Journeyman
nolabama's Avatar
seimens is good stuff in my opinion
Old 09-04-2010, 06:52 PM   #10
Chief Electron Relocator
Measure voltage across the breaker.
Old 09-04-2010, 06:54 PM   #11
Licensed Journeyman
nolabama's Avatar
quite a useful test
Old 09-04-2010, 06:54 PM   #12
I void warranties
Jlarson's Avatar
You measure the voltage drop across a contact or breaker. The higher the resistance the higher the voltage drop. The increased resistance is what causes the heat increase. I attached a visual example of how to do the test.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
frenchelectrican (09-05-2010), Magnettica (09-04-2010)
Old 09-04-2010, 06:57 PM   #13
Licensed Journeyman
nolabama's Avatar
why do you use the milliamp setting for this?
Old 09-04-2010, 06:59 PM   #14
I void warranties
Jlarson's Avatar
Cause I'm an idiot and meant mV not mA.
Ok I fixed it, all good now.
Old 09-04-2010, 07:43 PM   #15
B4T
ET Road Warrior
B4T's Avatar
I can't open a DOC file..
Anyone have this in a different format?
Old 09-04-2010, 07:44 PM   #16
I void warranties
Jlarson's Avatar
You don't have word? What about a pdf, I just put that option up.
There isn't much to see, I whipped it up in like 5 minutes.
Old 09-04-2010, 07:57 PM   #17
B4T
ET Road Warrior
B4T's Avatar
I had to save it on desktop and then it opened..
Old 09-04-2010, 08:22 PM   #18
Could you give me an example of typical values for this type of test and what would they mean? I understand the higher the resistance would cause a breaker to heat up but what are acceptable values?
For example would a 10 mV drop be significant? Or is the critical matter that the breaker feels hot?
Old 09-04-2010, 08:32 PM   #19
B4T
ET Road Warrior
B4T's Avatar
I just did a GOOGLE and this came up.. who knew..
Paging Brian John... FOP test
Old 09-04-2010, 08:33 PM   #20
I void warranties
Jlarson's Avatar
You should see almost 0 mV across a good contact, I reality 10mV or less is ok for most stuff. I just had a 60 amp QO two pole with 15 amps per leg start tripping, I measured a 33mV drop across A phase. The breaker was hot like, 2nd degree burn hot.
B4T (09-04-2010)
Service call mattsilkwood General Electrical Discussion 13 08-17-2010 10:45 AM
Service Call brian john General Electrical Discussion 5 08-11-2010 09:21 PM
Interesting service call today. captkirk General Electrical Discussion 30 06-09-2010 07:33 AM
So i got a call about a job today ryanapplequist Off Topic 17 12-03-2009 11:24 AM
So I did a service call in this Spa today steelersman Off Topic 30 10-27-2009 04:24 PM
