Old 09-17-2010, 10:08 AM   #1
Default Service Entrance Conductors Tap Rule
I have an install where I need to tap the SE conductors in the Load Center right before they land on the main breaker.
This is a residential install, I would use listed ilsco wire taps and then go directly into an inline fuse holder to protect the tap wires which will be #12 conductors that are sensing leads to a resi generator.
Ive looked at 240.21 and article 725 and also looked thru article 230 and cant seem to find anything prohibiting this, is this a legal install or am I grasping?
Thanks in advance
aksparky is offline   Reply With Quote
Old 09-17-2010, 10:22 AM   #2
Toronto Sparky's Avatar
I would say that local POCO may have something to say about that..
Don't fight .. Play nice!
Old 09-17-2010, 11:33 AM   #3
Fried Bologna um um good!
jwjrw's Avatar
Why? He said main breaker which would be service entrance cables. Not poco's feeder. Or am I mis understand you?
Old 09-17-2010, 11:35 AM   #4
jwjrw's Avatar
Thanks in advance
I'm not an expert on the tap rules but I'd say it is legal if you size the tap conductors properly.
Old 09-17-2010, 12:11 PM   #5
In my house the main disconnect is before the meter. (and has seal on it)
Not really related but here in Toronto (and I assume everywhere) the disconnects that feed elevators have a set of contacts (microswitch) that bypasses the return to lobby function when disconnect is shut off .. Do they make a main breaker with this contact?
Old 09-17-2010, 12:27 PM   #6
Nothing in 240.21 applies to service conductors .
You may be able to make the tap, but all the conductors must be larger then the connected load.
However, these taps would have to go directly to a service rated and bonded disconnecting means, they cannot simply run to fuse holders.
Old 09-17-2010, 12:41 PM   #7
jwjrw's Avatar
Sad thing is I know you are in Canada but didn't think about your codes being different. I believe our ocpd can only be on the load side of poco.
Old 09-17-2010, 03:29 PM   #8
It is not so much of a code issue as it is a utility preference. Some POCOs want a switch before the meter to disconnect the socket during meter change outs and what not.
Old 09-17-2010, 03:32 PM   #9
jwjrw's Avatar
I actually meant the utility codes. I've never seen a disconnect for a meter where I am.
Old 09-17-2010, 03:35 PM   #10
As I said My meter is after the disconnect, however the outside meters would be before the main disconnect..
My place has an indoor A-Base type meter the incoming feed goes to the line side of the disconnect then from load side to the meter , then to the main breaker on the panel.. (Originally the panel was a fuse panel with no main fuses in the panel as the disconnect handled fusing and disconnecting means.)
It also had a 30A plug fuse disconnect fed off the main disconnect load side that fed the flat rate water tank :-)
This house was built in the early 50s..
Old 09-17-2010, 03:36 PM   #11
Here it is a very common power company requiment for 480 volt services.
It can be a service disconnect with over current protection or it can be a non fused disconnect that the NEC calls a 'meter disconnect' you would still have to install a service disconnect on the load side of the meter.
Old 09-17-2010, 03:39 PM   #12
jwjrw's Avatar
Last 480v service I did was only 100a and they didn't require it here. Not saying other areas here don't require it. But in my short life I have not noticed one here. It's interesting to hear what some areas require and don't require.
Old 09-17-2010, 03:43 PM   #13
You likely will, it has to do with power company employee safety.
If you are plugging in a 7 jaw meter into a live 480 three phase socket it can cross, short and get real ugly fast.
Old 09-17-2010, 03:51 PM   #14
jwjrw's Avatar
I might even become 1/2 an union electrician one day if I study hard.
Thanks for the info Bob. I'm gonna start looking. I may of seen one without realizing it. But I know poco set a transformer on the pads we made and went to the meter on the last two we did. Is it possible they had a disconnect on their side in transformer box?
400 amp three phase service entrance jojoschauss Services and Service Equipment 13 07-21-2012 11:09 AM
Service Entrance silva.ac Services and Service Equipment 6 01-29-2009 05:51 PM
Service Entrance Conductors Absolutetruthz Services and Service Equipment 15 06-08-2008 03:16 PM
Service entrance walkerj Vintage Electrical 9 11-04-2007 12:06 AM
UG Service Entrance Hillbilly Services and Service Equipment 11 03-20-2007 09:33 PM
