Smart Meters - Electrician Talk - Professional Electrical Contractors Forum
Old 11-14-2012, 06:58 PM   #1
Rewards Points: 85
Default Smart Meters
Smart meters installed this weekend.
1 fire and 3 bad main breakers since. Hmmmm.
What do you guys think about smart meters?
I've opted out (for now at least) at my own home.
MrsElectric is offline   Reply With Quote
Old 11-14-2012, 07:06 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 390
I love fires. I've got one on my own home for 2 mos now. I have a 3r fused disco next to it for my service, thinking about putting a heat detector/shunt trip on it. Maybe some fire supression. the tin foil hat keeps the radiation from causing hallucinations so far.
Old 11-14-2012, 07:14 PM   #3
MWayne's Avatar
Rewards Points: 270
When the Co-op people changed mine out a few years ago they simply jerked the old out and slammed the smart meter in as fast as they could, thankfully it was in the fall and not much load. But I could easily imagine what could happen if the demand was150 amps or so with a device not designed to make or break.
MWayne is offline   Reply With Quote
Old 11-15-2012, 07:02 AM   #4
Rewards Points: 1,212
The problems have nothing to do with the smart meters. The same problems would have occurred if the conventional meter had been replaced with another conventional meter. The connections in the meter can and at the breaker bus were marginal to start with and the mechanical movement from the meter replacement was just the last straw.
The Following 5 Users Say Thank You to don_resqcapt19 For This Useful Post:
Big John (01-13-2013), carryyourbooks (11-15-2012), guest (01-13-2013), LARMGUY (01-13-2013), Rollie73 (01-13-2013)
Old 11-15-2012, 07:08 AM   #5
BBQ
Salty Member
BBQ's Avatar
Thank you for injecting commonsense into this.
It seems smart meters take the blame for everything from increased customer bills to the cause of hurricane Sandy.
The Following 4 Users Say Thank You to BBQ For This Useful Post:
220/221 (01-12-2013), big2bird (11-16-2012), guest (01-13-2013), LARMGUY (01-13-2013)
Old 11-15-2012, 07:13 AM   #6
Rewards Points: 946
While I tend to agree with you, our local POCO is accepting fault to a degree
http://articles.philly.com/2012-09-1...ers-new-meters
'I believe that banking institutions are more dangerous to our liberties than standing armies"
Thomas Jefferson
electricalwiz is offline   Reply With Quote
Old 11-15-2012, 07:18 AM   #7
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,284
Our complaint is that the tabs on the new meters are thinner, about 1/2 the thickness, than the old meters.
If the tabs do not have really good spring action left in them, they cook off when people start turning on their heaters in the winter.
Plumbers seem to get lots of stoppage calls on Thanksgiving
We get calls when the heaters come on for the first time
The AC guys get their calls when its gets into the low 90s here
Old 11-15-2012, 07:20 AM   #8
motherplucker
chicken steve's Avatar
Rewards Points: 4,302
Talked to a number of poco contractors (they farm out the installs) who are happening upon some rather obnoxious metering equipment
Unfortunately, they've all been told to wear the blinders, and simply do the swap out
So here we have a golden opportunity to address some serious metering issues that will go completely unnoticed , at least by the poco's meter readers, now
Old 11-15-2012, 07:21 AM   #9
BBQ
Salty Member
BBQ's Avatar
What is your solution and who will pay for it?
Old 11-15-2012, 07:26 AM   #10
BBQ
Salty Member
BBQ's Avatar
Are they half as thick as any meter or just half as thick as old meters?
In other words if a new dumb meter was installed would the situation be any diffrent?
I guess I am just a bit tired of all the BS around the web about smart meters. Some folks think they emit dangerous fields and devulge your family secrets.
Old 11-15-2012, 07:30 AM   #11
Rewards Points: 12,320
Thanks for the chuckle!
Giving up on unbiased truth.
Old 11-15-2012, 07:32 AM   #12
motherplucker
a very good question BBQ
and there is the spectre of liability as well
some of these contractors are yankin' meters i never would touch (i'll cut off an OH service first) , and have stories about the 'lug that came with it'
which they actually try to take off/place on live....
Old 11-15-2012, 07:35 AM   #13
motherplucker
you just need to get in touch with your inner Cletis BBQ....~CS~
Old 11-15-2012, 07:45 AM   #14
wildleg's Avatar
Rewards Points: 390
they farm out the meters here too. I casually debriefed the guy who was doing our block. Apparently they give them a class (one day ?) that teaches them everything they need to know. My guy had a face shield, gloves (he didn't know what rating was), glove protectors, and some hand tools. He wasn't an electrician or a lineman. Don't know what they are paying em, but I'm guessing it's by the meter or they have a quota.
chicken steve (11-15-2012)
Old 11-15-2012, 07:47 AM   #15
BBQ
Salty Member
BBQ's Avatar
I may have some inner eejack, maybe even some inner ~CS~ but there is no way I have any inner Cletis.
drumnut08 (01-13-2013)
Old 11-15-2012, 08:08 AM   #16
Data Tech/Apprentice.
Rewards Points: 22
Isnt the male cletis up your arse or is that the male D-spot?
Old 11-15-2012, 03:32 PM   #17
motherplucker
another distress call today...smart meter man......lug stuck....fire......
and i heard it was by the meter here WL
Old 11-15-2012, 03:39 PM   #18
BBQ
Salty Member
BBQ's Avatar
Another smart meter controlling someones thoughts or was it just letting the IRS know the residents where tax cheats?
Old 11-15-2012, 03:44 PM   #19
motherplucker
well it knew , because that's how smart it is!
i can hardly wait for the talking variety.......
Old 11-15-2012, 09:24 PM   #20
Rewards Points: 85
I agree
Was just wondering what others thought about them
I don't think the meter itself was the cause of the fire/bad breakers
I'm just not embracing one more way to be charged and controlled more than we already are
Smart Meters nchvac General Electrical Discussion 6 01-14-2013 09:44 AM
New smart meters Shawn23 General Electrical Discussion 0 01-25-2012 02:38 PM
More on Smart Meters wildleg General Electrical Discussion 2 10-22-2011 12:35 PM
Smart Meters dronai General Electrical Discussion 19 09-14-2011 11:46 AM
How Smart are Smart Meters Serge General Electrical Discussion 1 04-09-2010 12:10 PM
