Spray foam? - Electrician Talk - Professional Electrical Contractors Forum
Old 01-15-2012, 10:15 PM   #1
Elephante's Avatar
Rewards Points: 570
Default Spray foam?
Can you spray foam over romex wires? Are there any derating issues by doing that?
Elephante is offline   Reply With Quote
Old 01-15-2012, 10:20 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 384
I guess there would be if it melts all the insulation away. otherwise, I think there would have to be extenuating circumstances (o/w known as bundling) for there to be an issue
Old 01-15-2012, 10:23 PM   #3
LightsOn81's Avatar
Rewards Points: 548
Inspector here told us that it had to be fire rated
If it gets any better, I won't be able to stand it!
LightsOn81 is offline   Reply With Quote
Old 01-15-2012, 10:45 PM   #4
360max's Avatar
Rewards Points: 734
..are you going thru a fire rated wall?
Moderator-In-Training
Old 01-15-2012, 11:20 PM   #5
Elephante's Avatar
Rewards Points: 570
Have you ever seen bundling in a residential application?
Old 01-15-2012, 11:23 PM   #6
Bababoee
captkirk's Avatar
Rewards Points: 2,030
is spray foam any different than being packed in a wall with insulation..
Full time Bovine Scatologist.
The Following User Says Thank You to captkirk For This Useful Post:
jza (01-16-2012)
Old 01-15-2012, 11:33 PM   #7
Elephante's Avatar
Rewards Points: 570
foam attaches to the cable . thats the only difference i can think of
Old 01-15-2012, 11:37 PM   #8
Bababoee
captkirk's Avatar
personally i dont think its a problem, only because ive done several jobs with spray foam insulation on new homes and its never been mentioned.. I wouldnt worry about to much..
Old 01-15-2012, 11:49 PM   #9
Elephante's Avatar
Rewards Points: 570
Not really worried..I'm just waiting for an inspector to say someting."That can't be like that. You have to channel the foam out."lol
Old 01-16-2012, 12:15 AM   #10
Master Of Disaster
socalelect's Avatar
Rewards Points: 1,006
is the foam you speak of like " great stuff " that stuff is anything but great
Old 01-16-2012, 12:46 AM   #11
Bababoee
captkirk's Avatar
we had one guy give us a hard time once with MC and fire insulation in a new daycare center. We had to break it off in some areas.
Old 01-16-2012, 03:02 AM   #12
CDN EC's Avatar
Had to do it on one local resi home theatre job. Passed inspection just fine, the foam doesn't eat away at the plastic.
If you let the smoke out, you void the warranty. - NK
CDN EC is offline   Reply With Quote
Old 01-16-2012, 06:03 AM   #13
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Where more than two NM cables containing two or
more current-carrying conductors are installed, without
maintaining spacing between the cables, through the same
opening in wood framing that is to be fire- or draft-stopped
using thermal insulation, caulk, or sealing foam, the allowable
ampacity of each conductor shall be adjusted in accordance
with Table 310.15(B)(2)(a) and the provisions of
310.15(A)(2), Exception, shall not apply.
more current-carrying conductors are installed in contact
with thermal insulation without maintaining spacing between
cables, the allowable ampacity of each conductor
shall be adjusted in accordance with Table 310.15(B)(2)(a).
Old 01-16-2012, 06:06 AM   #14
motherplucker
chicken steve's Avatar
Rewards Points: 4,116
334.80
thank you McClary
Old 01-16-2012, 06:08 AM   #15
motherplucker
you wouldn't happen to have the HB commentary following that?
Old 01-16-2012, 06:12 AM   #16
evil bastard
Rewards Points: 746
I have a handbook, but not that I can cut and paste to here.
Old 01-16-2012, 06:53 AM   #17
Stab&Shoot's Avatar
Rewards Points: 250
Great Stuff spray foam is not permissible as a draft stop in any application thicker than 1". So if you drill through a 2"x4" bottom plate, then draft stop it with spray foam- you are in violation. I know this b/c an inspector failed me and I challenged him. I called the manufacturer of the foam to request a ms data sheet and was informed by Great stuff that it in fact is not good for any application over 1" thick. Had to dig all foam out holes and re caulk. Have never purchased as a draft stop again.
Stab&Shoot is offline   Reply With Quote
Old 01-16-2012, 11:23 AM   #18
Rewards Points: 2,012
A few years back I had that foam ins. burn thru some bell/phone cables.
What a PITA replacing that. Now I use the good cable.
Old 01-16-2012, 11:28 AM   #19
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,302
How about when some jerk off fills a receptacle box with spray foam on an exterior wall, those are always fun.
jza is offline   Reply With Quote
Old 01-16-2012, 11:31 AM   #20
wildleg's Avatar
Rewards Points: 384
I've only used the spray foam a few times on the odd resi job I did. I never had the issue with eating the sheath or with the inspector saying it wasn't suitable, as were indicated above. It seems ludicrous that the foam can't be used for draft stopping (AFAIK they allow anything and everything around here for draft stopping) - of course, I'm not talking about firestopping, which requires a rated material. And draftstopping in a wood wall that requires fire blocking, would of course require fire rated material. So I'm a little suprised that foam is not allowed - I'm gonna check that out next time I have a job like that. Anybody have an idea where that might be in any of the codes ? (IRC ?)
Wallpacks with Spray Paint A_D General Electrical Discussion 15 11-30-2011 07:17 PM
head up with expanding insluating foam frenchelectrican Workplace Safety 23 07-11-2011 11:30 PM
Foam sprayed attics Shawn23 Other Codes and Standards 11 02-25-2011 07:08 PM
spray foam s.kelly General Electrical Discussion 28 06-05-2010 09:01 AM
Spray can pvc cement macmikeman Tools, Equipment and New Products 5 04-07-2009 11:44 AM
