Old 04-23-2011, 03:07 PM   #1
Default SqD QO Quads?
Is it just me, or does SquareD not make Quad breakers in the QO line?
splotchhide is offline   Reply With Quote
Old 04-23-2011, 03:32 PM   #2
Chief Electron Relocator
You mean like the Westinghouse/Bryant/ITE/CH type?
Old 04-23-2011, 03:43 PM   #3
Yes, exactly. But for a QO panel. I see that SquareD makes them for Homeline panels.
Old 04-23-2011, 05:12 PM   #4
PGW Professional
Magnettica's Avatar
A real electrician would do the right thing and upgrade the panel instead of putting a band-aid on a gun shot wound. I know plenty of union electricians who are way, way better electricians than you.
Old 04-23-2011, 05:14 PM   #5
erics37's Avatar
I don't think they make 'em. Can't find anything other than QO twins.
- Eric
Old 04-23-2011, 05:16 PM   #6
I have a black cat.
Rudeboy's Avatar
If he was just adding a circuit what would be the problem with using a quad? I don't know if they make them for QO but I used a quad for a Homeline recently and I use them for CH all the time.
I don't like to Save time and money.
Old 04-23-2011, 05:31 PM   #7
PGW Professional
Magnettica's Avatar
The problem is the OP may lack the skill required to do this type of installation.
Old 04-23-2011, 05:38 PM   #8
Send a message via Yahoo to gold
obvious but ...
Twin the sp ckts to make room if you cant replace the whole panel or add a sub.
gold is offline   Reply With Quote
Old 04-23-2011, 05:45 PM   #9
I have a black cat.
Rudeboy's Avatar
Originally Posted by gold View Post
obvious but ...
Yeah but if they're mwbc, no handle ties.
Not that that's stopped me before.
Old 04-24-2011, 10:53 AM   #10
Just looked in my Square D Digest & there is no listing for a QO tandem quad breaker.
alpha3236 is offline   Reply With Quote
Old 04-24-2011, 03:25 PM   #11
Square d do makes a 20/30 double tandem in the QO line. They are expensive, about $ 80.
hasor is offline   Reply With Quote
Old 04-24-2011, 03:42 PM   #12
Electric Al
oldtimer's Avatar
Show a pic!
I'd rather have a bottle in front of me , than a frontal lobotomy. ( Quote from Tom Waits. )
Old 04-24-2011, 04:09 PM   #13
Old 04-24-2011, 04:12 PM   #14
That pic doesnt show it , but it does come with a handle tie
Old 04-24-2011, 05:07 PM   #15
whats the advantage of a quad pole vs 2 tandem??? it takes the same space
Old 04-24-2011, 09:54 PM   #16
Big differance. Two tandems create 4 different circuits from 2 spaces. A quad is two 240V circuits in 2 spaces. The two inner handles are connect as usual. And the two outer handles are connected with a 'U' shaped bracket. This is to allow either of the 2p circuits to trip without affecting the other.
DCAC is offline   Reply With Quote
Old 04-24-2011, 09:57 PM   #17
Go to http://www.schneider-electric.us/ . I think thats the site to look up square D parts.
Old 04-24-2011, 09:59 PM   #18
NRA Member
backstay's Avatar
Nice to have when panel space is used up. I like to spread the load out some, say the 20 amp 2P is for some type of heat and the 30 amp 2P is an AC unit or visa versa.
Old 04-24-2011, 10:30 PM   #19
"A" Inside Wireman LU 134
Hack....
Piping as long as I can...
pugz134 is offline   Reply With Quote
Old 04-25-2011, 01:30 AM   #20
Master Plumber
TOOL_5150's Avatar
Thats only a quad if the inner 2 and outer 2 are tied together, otherwise its just a triplex. The breaker 480 posted is a quad.
~Matt
Poor planning on your part does not constitute an emergency on my part.
