Old 01-26-2011, 07:28 PM   #1
Default Stripping wire with your dykes
It may be a hack to some but i can strip a lot with my dykes without leaving a knick in the conductor. Anybody else just use dykes?
I'm talking about romex and thhn sizes #14-#10
I knick the outer jacket with my dykes and strip the conductors with them too sometimes.
Makes it so much quicker using one tool making up a panel.
No knicks whatsoever. I have had the same pair of dykes for going on 10 years so you get the feel of them and how hard to close them on the wire.
I can even do stranded without knicking the wire but i always use strippers for that.
pawirenut is offline   Reply With Quote
Old 01-26-2011, 07:36 PM   #2
I had stripping dykes when I did resi, used them for switching and plugging. For rough wiring I used 9" Kleins.
http://www.service.kleintools.com/To...NAL-HLSTRPHOLE
Brian John
Leesburg, VA
Old 01-26-2011, 07:38 PM   #3
I use my thin screwdrivers as chop sticks...
The Following 4 Users Say Thank You to Dennis Alwon For This Useful Post:
alpha3236 (01-26-2011), Chris1971 (01-28-2011), Flashlight (02-01-2011), jeffmoss26 (07-25-2012)
Old 01-26-2011, 07:42 PM   #4
B4T
ET Road Warrior
B4T's Avatar
I use these to strip up to #3THHN.. rather have one tool that does it all
The Associated Press wants to stop using the term "Illegal Aliens".. they say it is demeaning.. .. instead they want us to use Undocumented Democrats... Jay Leno..
dhanson (01-29-2011)
Old 01-26-2011, 07:44 PM   #5
sparky105's Avatar
Lines man for all except panel work or control
sparky105 is offline   Reply With Quote
The Following User Says Thank You to sparky105 For This Useful Post:
leland (01-27-2011)
Old 01-26-2011, 07:45 PM   #6
Ayuh
Ima Hack's Avatar
I would only do that if was all the way up in attic and forgot my strippers or something like that. To much of a risk to damage the conductor in my opinion. But what do I know.
I give that method about a 4 on the hack-o- meter.
Hire a teenager while they still know everything.
Ima Hack is offline   Reply With Quote
Old 01-26-2011, 07:48 PM   #7
Heavily Armed Member
HARRY304E's Avatar
In 1994 i bought a pair of 2000-28 klein dykes the first thing i cut with them was live 120 volts..
Woops well that made them a good pair of strippers..http://www.service.kleintools.com/To...oduct/D2000-28
The Following 4 Users Say Thank You to HARRY304E For This Useful Post:
B4T (01-26-2011), CraigV (07-25-2012), Englishsparky (01-26-2011), Semi-Ret Electrician (07-25-2012)
Old 01-26-2011, 07:51 PM   #8
When your good at it like me you don't knick the conductor its all in the wrist
And i use my strippers most of the time but if i really want to knock things out quick i use one tool.
Maybe i should make a video of it
Old 01-26-2011, 07:51 PM   #9
Been there, I had one pair of Kleins that could strip 4/0.
Brian John
Leesburg, VA
HARRY304E (01-26-2011)
Old 01-26-2011, 07:52 PM   #10
That's around how old mine are same kind Klein blue handle.
Old 01-26-2011, 07:54 PM   #11
HARRY304E's Avatar
277 volts?
Old 01-26-2011, 07:56 PM   #12
jza
I'm so impressed!!
jza is offline   Reply With Quote
The Following User Says Thank You to jza For This Useful Post:
kawimudslinger (09-29-2011)
Old 01-26-2011, 08:01 PM   #13
HARRY304E's Avatar
Its funny when i did that i was going to just get another pair but never did
They still work fine.
I have beet about 5 pairs of 9" linesmen since then..
Old 01-26-2011, 08:03 PM   #14
B4T
ET Road Warrior
B4T's Avatar
Originally Posted by jza View Post
I'm so impressed!!
Do you ever have anything good to say??
The Following 2 Users Say Thank You to B4T For This Useful Post:
HARRY304E (01-26-2011), Ima Hack (01-26-2011)
Old 01-26-2011, 08:03 PM   #15
HARRY304E's Avatar
I'm so impressed!!
Stick around kid you will learn
Old 01-26-2011, 08:05 PM   #16
Yep and i have cut tons of 6,8 and 10-32s with them over the years and still work good.
Old 01-26-2011, 08:08 PM   #17
Master Plumber
TOOL_5150's Avatar
whats wrong with strippers?
I use ideal strippers for everything, from stripping #14 to cutting 10-3 MC and everything in-between.
~Matt
Poor planning on your part does not constitute an emergency on my part.
The Following User Says Thank You to TOOL_5150 For This Useful Post:
captkirk (02-01-2011)
Old 01-26-2011, 08:10 PM   #18
HARRY304E's Avatar
You can strip 750's with these.
Old 01-26-2011, 08:17 PM   #19
You know, you can cut wire/NM sheath with your strippers .
I've of course used dikes/sidecutters in a pinch but, I much prefer new, sharp strippers and I guarantee I can strip wire faster than you can with 10 year old dikes.
GAH!!
The Following User Says Thank You to 220/221 For This Useful Post:
TOOL_5150 (07-26-2012)
Old 01-26-2011, 08:22 PM   #20
I can also spin my klien linemans on my finger
Mr Rewire is offline   Reply With Quote
stripping data cable jacket - Seatek tool BP_redbear Tools, Equipment and New Products 11 04-28-2010 09:35 PM
Stripping Romex mikeg_05 General Electrical Discussion 75 04-16-2010 07:54 PM
Strongest linesmen or Dykes? bushwickbill Tools, Equipment and New Products 75 03-10-2010 06:20 PM
What to use when stripping romex? Gents Tools, Equipment and New Products 46 12-20-2008 08:44 PM
Stripping Romex reqs. subelect NEC Code Forum 14 07-16-2008 07:05 AM
