Stumped! Continuity but no voltage. - Electrician Talk - Professional Electrical Contractors Forum
Old 10-07-2010, 03:07 AM   #1
Post Stumped! Continuity but no voltage.
Any help would be appreciated... Today I had a customer who's stairway night lights were out (120 volt). I checked the photo sensor outside and it was fine. The photo sensor feeds two lights over the garage doorway before the line runs into the house and to the stairs.
I put a tone generator on the line at the stairs (black only) and got a strong signal at the photo sensor. Same for the neutral.
I bypassed the photo sensor and the garage lights work fine, but still no stair lights. I get about 2 volts at the stairs. Turned off the breaker and voltage dropped to 0.
I'm stumped. Any ideas? Anyone? Thanks!
hometodos is offline   Reply With Quote
Old 10-07-2010, 03:10 AM   #2
Jlarson's Avatar
Rewards Points: 2,758
2 volts from what to what? Ungrounded to grounded, ungrounded to grounding?
Old 10-07-2010, 03:22 AM   #3
erics37's Avatar
Rewards Points: 638
Did you physically open up the 2nd garage light and check out the connection feeding in to the stairs?
A toner has it's place but I prefer physically checking splices if part of a circuit is mysteriously not working after a certain point.
Old 10-07-2010, 03:24 AM   #4
Eeeeeevil Bitch
BCSparkyGirl's Avatar
Rewards Points: 1,014
really, silly question, but sometimes it's the right one.....did you check the light bulb itself? Or flip the breaker? Or that gfi hidden in the garage for some weird reason?
BCSparkyGirl is offline   Reply With Quote
Old 10-07-2010, 03:27 AM   #5
I own stock in FotoMat!
Rewards Points: 6,520
Time to call an electrician.
Old 10-07-2010, 03:53 AM   #6
Yes, erics37, I checked both lights over the garage and the wiring is fine.
Answer to BCSparkyGirl: My tests at the stairs were on the line feeding it, with the chain of lights diconnected. (they all work fine with another power source). No GFCI on this circuit. Breaker not tripped.
Answer to Jlarson: 2 volts AC black/white wires
Old 10-07-2010, 04:19 AM   #7
Rewards Points: 3,855
Your initial assumptions as completely incorrect. You state, "continuity but no voltage", yet you checked continuity with a toner? Give me a break. Get out an extension cord or roll of THHN and check with a meter. Something's broke somewhere.
hotwire1955 (10-07-2010)
Old 10-07-2010, 04:31 AM   #8
Ok MDShunk. I'll do that. thanks.
Old 10-07-2010, 04:33 AM   #9
Jlarson's Avatar
Did ya check from hot to ground?
Yeah, not my first choice either.
Old 10-07-2010, 07:05 AM   #10
Rewards Points: 79
gonna have to go with 480 on this one....
a toner???????
Marshall175 is offline   Reply With Quote
Old 10-07-2010, 08:16 AM   #11
Mostly Harmless
Split Bolt's Avatar
Rewards Points: 1,008
Tone generators can actually be wonderful troubleshooting tools in some situations! They work perfectly with romex. I've had mine lead me to tripped GFI receptacles in 2 different basements. In both cases, the homeowner had no idea that those receptacles even existed. One was in a linen closet behind some towels and another in an unfinished area behind a bunch of boxes!
"Golf is a good walk spoiled." -Mark Twain
Split Bolt is offline   Reply With Quote
Old 10-07-2010, 08:19 AM   #12
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
broken wire, or bad splice.
Old 10-07-2010, 03:26 PM   #13
I_get_shocked's Avatar
Rewards Points: 516
Begin by switching to low impedance or a solenoid meter. Then once you discover you have 0 volts, switch to continuity and find the break
I_get_shocked is offline   Reply With Quote
Old 10-08-2010, 02:04 AM   #14
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 5,130
Toners only work on normally open wires, short them together and the tone stops.
LARMGUY is online now   Reply With Quote
Tags
night lights, photo sensor
I'm Stumped geo5509 Residential Electrical Forum 19 05-14-2010 07:27 PM
Anyone use the VT154 Audible Voltage Continuity Tester? foolios General Electrical Discussion 0 11-23-2009 08:16 PM
breaker on, wires have voltage; breaker off, wires have continuity. How can this Be? Weskey General Electrical Discussion 6 10-08-2009 09:47 PM
im stumped CNC General Electrical Discussion 17 10-08-2009 03:00 AM
Stumped BIGRED General Electrical Discussion 37 03-01-2007 03:29 PM
