t12 ballast replacement question - Electrician Talk - Professional Electrical Contractors Forum
Old 04-17-2011, 03:46 PM   #1
Rewards Points: 81
Default t12 ballast replacement question
ive got a few older t12 2 lamp fixtures that need ballasts. Differently than new electronic replacement ballasts, the existing ballasts have 1 blue lead and 1 red lead, and obviously a line and neutral. The electronic replacements ive been able to find have 2 blue and 1 red lead. Can i run these by capping off the unused blue lead? Being fairly new to this, I havent seen any of these before. Thanks for any help you may be able to give.
Also, i have a new t12 electronic replacement laying around so i gave it a shot by using both blue leads to the fixture blue lead, red on ballast to red on fixture and they burned fine for a few them went out. Im assuming the thermal protection in the ballast caused this.
Any help would be greatly appreciated.
adamv7010 is offline   Reply With Quote
Old 04-17-2011, 03:50 PM   #2
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,080
8' fixtures?
There should be a diagram present right on the ballast
farlsincharge is offline   Reply With Quote
Old 04-17-2011, 03:50 PM   #3
Rewards Points: 218
you'll need to rewire the tombstones, to make it work correctly, the new ballast lights the lamps independantly
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
The Lightman (04-18-2011)
Old 04-17-2011, 03:53 PM   #4
Rewards Points: 81
yes but nothing i can find has only 1 blue lead and only 1 red lead. However it does say for "N1" operation cap unused blue lead. im not familiar with what n1 operation is
Old 04-17-2011, 03:55 PM   #5
Speedy Petey's Avatar
Rewards Points: 1,780
Just follow the wiring diagram on the ballast. EVERY ballast has one.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
John Valdes (04-18-2011), randas (04-17-2011)
Old 04-17-2011, 03:56 PM   #6
Sideways Sparky
I'm going to go out on a limb and say N1 is for 1 lamp.
1 blue to each tombstone on one end and the red to both on the other.
Old 04-17-2011, 04:01 PM   #7
NRA Member
backstay's Avatar
Rewards Points: 750
Just did 4 of these. The two blues go to the lamps on one end(one wire to each holder), the red goes to the other end(the one red wire to both lamps). The hot and neutral are now going to the lamps on one end. They will have to be cut and run directly to the ballast.
adamv7010 (04-17-2011)
Old 04-17-2011, 04:02 PM   #8
Rewards Points: 81
id rather not rewire the sockets...
Old 04-17-2011, 04:05 PM   #9
Rewards Points: 81
iirc a universal 820 mag replacement is what i need...but i dk if i can find any anymore
Old 04-17-2011, 04:09 PM   #10
william1978's Avatar
Rewards Points: 2,000
Beggars can't be picky.
The Following User Says Thank You to william1978 For This Useful Post:
Speedy Petey (04-17-2011)
Old 04-17-2011, 04:11 PM   #11
NRA Member
backstay's Avatar
Rewards Points: 750
You just cut the wires and wire nut the new leads in. That part is easy. If you can't do that...well maybe you shouldn't do the job.
The Following 3 Users Say Thank You to backstay For This Useful Post:
John Valdes (04-18-2011), randas (04-17-2011), Speedy Petey (04-17-2011)
Old 04-17-2011, 04:11 PM   #12
Sorry but you don't get to make that decision any longer. At least not for much longer.
My supply house hasn't carried mag ballasts for quite a while now. I have been re-wiring fluorescents ever since.
Old 04-17-2011, 04:13 PM   #13
Rewards Points: 81
lol thanks guys.
Old 04-17-2011, 04:14 PM   #14
Sideways Sparky
Are anyone else's Landlord/maintenance man senses tingling?
The Following 2 Users Say Thank You to farlsincharge For This Useful Post:
sbrn33 (04-17-2011), Speedy Petey (04-17-2011)
Old 04-17-2011, 04:20 PM   #15
From the very beginning.
The Following User Says Thank You to Speedy Petey For This Useful Post:
william1978 (04-17-2011)
Old 04-17-2011, 04:33 PM   #16
Yep!!!
Old 04-17-2011, 09:07 PM   #17
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
as soon as I read post #8
Old 04-17-2011, 09:21 PM   #18
Dierte's Avatar
Rewards Points: 250
Love it! I had a whole day of replacing t12 electronic ballasts because the "guy" who had been replacing them for 20 years got confused and just matched colors w/o rewiring the tombstones
Dierte is offline   Reply With Quote
Old 04-18-2011, 01:33 PM   #19
Rewards Points: 772
You don't have to rewire the sockets. The one red wire connects to both tombstones on the red end. Just cut the old power wires and wirenut both tombstones together. All four wires go to the ballast red. Just like the drawing shows on the ballast.
How could he match colors when there are not enough wires to match up.
Old 04-18-2011, 04:19 PM   #20
Rewards Points: 250
Don't follow this advice, you will be back in a few months replacing all the ballast. I learned the hard way. You most defiantly need to desire the tombstones, or get rapid start electronic ballasts.
Tried that in my house being lazy, sure enough two months later light stopped working. Re wired tombstones and replaced ballast, two years later all good.
Foestauf is offline   Reply With Quote
Replacement Reginald18 Services and Service Equipment 5 10-30-2010 06:29 PM
Code question - Ballast replacement annnelson General Electrical Discussion 11 01-26-2010 08:14 PM
Replacing 8, 2 lamp magnetic ballast lighting with electronic ballast and t8 lamps phish1985 General Electrical Discussion 4 03-02-2009 03:57 PM
Replacement for old ITE 15A breaker WoodyW1952 Vintage Electrical 3 05-23-2007 07:29 AM
DIY 3-way replacement ! MDShunk Code Violation Discussion 4 04-02-2007 10:46 PM
