Tapping 200 Amp panel to a 150 sub panel? - Electrician Talk - Professional Electrical Contractors Forum
Old 07-06-2011, 08:15 PM   #1
Rewards Points: 25
Lightbulb Tapping 200 Amp panel to a 150 sub panel?
I am installing a 200 amp panel on the unattached garage. I am running a 150 amp MB sub to the inside of home. I need to know if I can tap off the main panel or would I need to add a 150 amp breaker in the main panel? Need to know the codes if you know them.
Thanks for looking.
Reseman
Reseman is offline   Reply With Quote
Old 07-06-2011, 08:19 PM   #2
Rewards Points: 272
How about some more info. Where is the panel ? What size wire? etc. Do you really need a 150amp feeder and if so will the service handle it?
Old 07-06-2011, 08:23 PM   #3
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
Thanks for looking.
Reseman
Are you using one of those feed-thru panels?..If so, use 200 amp wire(and a 200 amp mlo panel) and you are good to go. If you want a "feeder tap" you need to look at 240.21 b...
REMOVED
Old 07-06-2011, 08:30 PM   #4
Rewards Points: 272
If it is a feed thru panel then the wire must be rated for 200 amps.
Old 07-06-2011, 08:32 PM   #5
child please.....
Rewards Points: 14
Yeah that is why I said "use 200 amp wire"...
REMOVED
Old 07-07-2011, 02:33 AM   #6
Rewards Points: 534
Thanks for looking.
Reseman
IMO it will be cheaper just get the feed thru panel and run 200 amp sized conductors than try to buy a two pole 150 amp breaker that sucker is NOT cheap and not all place will have it stock escpally with push on loadcentre with common useage in resdentail { unless you got lucky with NQOD panel which they are typically bolt on then it will be a brezze }
Merci,
Marc
Old 07-07-2011, 02:55 PM   #7
A Little Short's Avatar
Rewards Points: 76
If he's running to the house from a separate (unattached) building, he would need a disconnect unless he has 6 or less breakers. You can get a MB panel sometimes cheaper than a MLO. IMO, less trouble to just put in a MB panel than to have to add a disconnect.
Edit: I agree with needing a 200A.
Old 07-07-2011, 02:56 PM   #8
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
That's how I would do it.
SEC passing thru a panel fedding another panel jwjrw NEC Code Forum 34 08-15-2011 09:33 AM
Spa panel and hot tub besc Residential Electrical Forum 25 05-20-2011 06:56 PM
Converting old SQ.-D QO panel to sub-panel subelect Services and Service Equipment 14 12-22-2010 02:53 AM
Sub panel feeding another sub panel electrocop General Electrical Discussion 11 03-02-2010 10:59 AM
Sub Panel Electric pole NEC Code Forum 16 10-25-2009 01:44 PM
