Old 05-03-2012, 11:00 AM   #21
Question
Originally Posted by Theriot View Post
A parish gym called for me to run power to two 20 ton a/c 3 phase units that will be installed tomorrow. Here's a pic of their three phase main disconnect.
It is remotely possible that you have a corner grounded 3 phase delta system there. You are only required to have fuses on the UNGROUNDED conductors. I know the one set of wires eventually has white tape on it, DOWNSTREAM of the splitter block, but I have seen that mistake made before by someone who didn't know about corner grounded delta services and assumed it was a neutral. A simple test is to measure the line to line voltage, not the line to ground voltages.
The Following 5 Users Say Thank You to JRaef For This Useful Post:
Big John (05-03-2012), chicken steve (05-03-2012), Electric_Light (05-04-2012), jmsmith (05-03-2012), nolabama (05-03-2012)
Old 05-03-2012, 08:41 PM   #22
Licensed Journeyman
nolabama's Avatar
Depending on the parish, he is prolly right. Strange combos have been delivered by older poco in this area.
Old 05-03-2012, 08:46 PM   #23
ampman's Avatar
Originally Posted by Wirenuting View Post
With "Your" time and "Their" money, it looks like an easy solution.
that has to be the post of the year -- do you mind if i use it
ampman is offline   Reply With Quote
Is it possible to use a single phase ballast on a two phase service receiver? Scallywag General Electrical Discussion 1 12-21-2011 05:59 AM
Single phase genset feeding 3 phase panel 220wire NEC Code Forum 9 11-19-2011 09:16 PM
3 Phase Switch Gear, Single Phase Panel AaronJ General Electrical Discussion 11 02-02-2011 01:19 AM
Single & Three Phase Motor Loads on Three Phase Circuit josefbartos NEC Code Forum 4 09-05-2010 01:31 PM
Using a variable freq control to run a 3 phase motor on 1 phase. rogersmithiii PLCs, VFDs, Motors and Controls 33 02-09-2010 12:54 PM
