05-04-2012, 02:07 AM
#21
IET
Originally Posted by Peter D
$6 billion will buy you a lot of stainless, and everything else.
It's like 3$ per foot for the 3/8"
The Following User Says Thank You to RobRoy For This Useful Post:
05-04-2012, 02:11 AM
#22
Heavily Armed Member
He said he uses a 555. I don't think that Ridgid tool will bend hard stainless tubing.
Here are the spec on the one I posted,I did not say it is the best tool for the job in fact I have not done any of that stuff for 15 years sorry if you don't like it.
358 5/8 OD RTCHT BENDER- These tools, with high geared mechanical ratios, bend heavy-wall steel tube (up to 1/8" wall thickness), stainless steel tube (up to 3/32" wall thickness), and hard copper water tube (types K and L)
- Benders produce uniform bends up to 180°, with no need to anneal tubing or use special temper grade tubing
05-04-2012, 02:13 AM
#23
Originally Posted by 360max
google
Wow Google does everything....
05-04-2012, 02:16 AM
#24
IET
This is my whole drivers side flip up bin. ALL STAINLESS FITTINGS!
There is a hell of a lot of money sitting in that flip up bin, not rusting away!
05-04-2012, 02:19 AM
#25
Looks good Robroy, great job. I noticed on the split straps you did not us rubber, on all the SS I've seen they always used the rubber, is there a reason for this (ie; cut down on vibration)?
05-04-2012, 02:20 AM
#26
I void warranties
Those new imperial benders are too fancy looking.  I'll take my old imperials and kbs rollobend benders any day.
The best never stop learning.
05-04-2012, 02:23 AM
#27
IET
Yeah, we were in a bind, and those were all that we're available! I like the rubber ones a lot more.
05-04-2012, 02:24 AM
#28
IET
Originally Posted by Jlarson
Those new imperial benders are too fancy looking.  I'll take my old imperials and kbs rollerbend benders any day.
After a day, you will love them. It took a little getting used to. Nothing a couple swear words couldn't fix!
#29
Robroy, what the deduct for a 90 degree bend?
05-04-2012, 02:26 AM
#30
I void warranties
Where are they making them now? Usa still?
05-04-2012, 02:27 AM
#31
Swear words fix everything...
05-04-2012, 02:29 AM
#32
IET
Fućk yeah they do!
05-04-2012, 02:48 AM
#33
IET
There isn't one. You mark it where you want the back of your 90, and put that on the "L" mark.
05-04-2012, 09:43 AM
#34
Should be working
Good looking work Robroy. How many field electricians in your company ?
05-04-2012, 10:24 AM
#35
crispy critter
sharpie
Great job RobRoy as usual. My only complaint is the marks. To me it takes away from the "good looks" of your pipe work when you leave a sharpie ring around the whole pipe. If I use a sharpie I try to make a tiny mark that no one can see, and then I spend an hr looking for my mark  Anyways, Im just a little OCD. Great job man
I'm old enough to know better, but too young to care.
05-04-2012, 11:22 AM
#36
Looks like a nice, clean job. I used to work in an instrument shop that built analyzers. I ran lots of micro-polished stainless during that time. Man, that's a small fortune in swage-loks in those bins. Do you program the smart transmitters too?
Mark
05-04-2012, 01:40 PM
#37
I have to agree, It was looking real good until I seen the sharpie rings.
IMO Sharpie marks on pipe just screams Rookie.
Other than that it looks cool.
05-04-2012, 02:08 PM
#38
Master Electrican
Actually there are deductions but their so minute and the tubing is so pliable that they really don't come into play, especially when you bend it like you referred to. But when doing offsets and saddle or having to turn the bender around some measurements are required.
The Following User Says Thank You to sstlouis03 For This Useful Post:
05-04-2012, 04:34 PM
#39
Electron Flow Consultant
Who cares about sharpie marks
The Following User Says Thank You to sparky970 For This Useful Post:
05-04-2012, 05:06 PM
#40
crispy critter
obviously not you
