Old 12-19-2007, 12:30 PM   #1
Default Tripping problems
I installed a new consumer unit today,but when connecting the shower to the rcd and switching the power on,the rcd trips.The wiring is correct so what could the problem be?
giarc84 is offline   Reply With Quote
Old 12-19-2007, 03:27 PM   #2
frank's Avatar
Could be anything. You need to disconnect the Shower from the local isolator and test the circuit again. Then test the shower. Insulation tests will indicate the problem for you.
Old 12-20-2007, 07:54 AM   #3
Default Reply
Your help is much appreciated.I rarely do domestic work so don't often encounter problems.I thought better to consult someone before doing something wrong.Does it have to be a megger i use or would the ohms setting on a multimeter be suitable?
Old 12-20-2007, 11:45 AM   #4
Bkessler's Avatar
What?
When ls lunch
Old 12-20-2007, 02:57 PM   #5
frank's Avatar
You really should not be asking such a question. MEGGER.
former employer problems tjl General Electrical Discussion 22 11-16-2008 08:11 PM
Tripping NRG General Electrical Discussion 5 08-15-2008 07:48 PM
Furnace problems calimurray General Electrical Discussion 10 01-05-2008 08:53 PM
RCBO Problems jonny_know_it Structured Wiring 2 09-24-2007 07:39 AM
qualification problems? speed967 General Electrical Discussion 3 07-07-2007 06:14 PM
