Closed Thread
Old 03-30-2007, 05:55 PM   #1
Default Troubleshooting bedroom outlet wiring?
The one bedroom wall outlets where my daughter is living are not working. I tested the respective breaker and there is 115 volts there. However none of the 4 outlets in that room are have voltage at the outlet plugs. There is voltage at the wiring to the outlets. There are 3 wires + one equipment ground wire. I tried reading across all 3 wires, nothing. I then read across the equipment ground wire to each of the other 3 wires individually. They all have voltage. I'm using my wiggy tester and the voltage appears to be just under 100 volts. Shouldn't one of these wires be a neutral leg? If it is, how can I identify which one that is, when they all are reading voltage across the equipment ground wire? I believe this is also the type of outlet that is wired with a light switch to bring on a lamp. Is that normally the lower outlet plug? Any help will be greatly appreciated. Thank you, Tommy.
Operator4819 is offline
Old 03-30-2007, 05:58 PM   #2
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
MDShunk is offline
Closed Thread
troubleshooting my design? Spat72 Lighting Design 5 03-29-2009 05:47 PM
Troubleshooting outside lights Roger123 General Electrical Discussion 18 02-25-2009 12:32 AM
Troubleshooting p_logix General Electrical Discussion 34 06-13-2008 09:12 PM
outlet katessa General Electrical Discussion 13 04-21-2008 08:08 PM
Troubleshooting Section Roger123 Site Help and Suggestions 1 10-17-2007 04:26 PM
