03-03-2009, 11:01 AM
Troubleshooting Emergency Lights
277 volt emergency light is not working at a plant I am working at. So far I have replaced the battery, didn't help. I do have 277 coming in and when I press the test button the lights come on ever so dimmly for a a second or to. Have inspected for loose wires or burn spots but have found neither. Is there anything else I can do besides replacing the unit?
Thanks as always!
Pete
03-03-2009, 11:16 AM
I hate emergency lights!
If the lamps light at all, other than changing the battery what else can you do? There is not much to them.
If they are at all older I just replace them.
04-28-2010, 05:14 AM
EMergency lights
I'm having problems with our emergency lights which does not work even if you unplug or push the test button.. Is there a way to repair this emergency lights? what do i have to replace?
04-28-2010, 05:33 AM
976-EVIL
In your situation, I would do what the op did first, change the battery.
04-28-2010, 07:37 AM
Just a question. Are these flourescent fixtures?
04-28-2010, 07:57 AM
Hook the lights up to the battery,directly.Verify they run for 90 mins. If not ,change unit.
04-28-2010, 08:28 AM
For what emergency lighting costs the older ones I change out to LED's. If it's not the battery or the bulbs it's cost prohibitive to troubleshoot IMHO.
04-28-2010, 09:04 AM
Big Daddy
Been there, just change them out. Then you'll know that you will have good units. Nothing is worse than finding out that the lights won't work properly when you need them the most. Worth the cost in my opinion.
04-28-2010, 09:32 AM
If you are on maintenance, have you checked the output of the charging network?
04-28-2010, 11:41 AM
Square D
Changed all of our EM packs to LED...it's just the way to go
04-28-2010, 04:05 PM
animal lover /rat bastard
spending time trying to fix emergency lights is a waste of money IMO replace and toss
04-28-2010, 04:10 PM
Chief Electron Relocator
Unless they're LEDs, it's just cheaper to change them out completely.
