Troubleshooting outside lights - Electrician Talk - Professional Electrical Contractors Forum
Old 02-05-2008, 10:47 PM   #1
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,192
Default Troubleshooting outside lights
Hi all,
I'm having some trouble with finding the problem on why a set of outside garage lights are failing intermittently. The home owner advised that the lights seems to fail when the weather is damp, rain or snow.
Can anyone suggest any troubleshooting suggestions I may try to locate this interment problem?
TIA
Old 02-05-2008, 11:12 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
What exactly is failing? Bulbs? Slices? The fixture themselves? The sockets? Are they motion sensors? Photocell-controlled?
Old 02-05-2008, 11:17 PM   #3
Yeah Toast!!
Roger123's Avatar
They are motion sensors/photocell controlled. The light fixtures sometimes do not light at night when they are suppose to. Owner advised that this seems to happen during damp weather.
Old 02-05-2008, 11:34 PM   #4
Rewards Points: 250
Buy good motion sensor.
Home depot crap will be call back city.
I've learned my lesson.
Buy a good cobra or somthing of quality.
Probably $60.00
faber307 is offline   Reply With Quote
Old 02-05-2008, 11:41 PM   #5
Rewards Points: 732
Rewire the taps. Squirt noalox inside the wirenuts. Make sure all the joints are secure. Pry the center tab of the socket out a tad. Put noalox on the screwshell of the lamps. And, replace the sensor. And while it may not be standard practice, you might seal the seams on the sensor with a thin coat of a clear silicone
InPhase277
Old 02-07-2008, 10:57 AM   #6
Yeah Toast!!
Roger123's Avatar
Thanks for the responses guys.
Does anyone think that there could be a conductor insulation problem somewhere in the circuit that could cause the said problem?
Old 02-07-2008, 04:22 PM   #7
R.I.P. 2014
Lesser quality photocells often are very tempermental in cold or wet weather. Put in a quality photocell and you'll probably never have an issue again.
Old 02-07-2008, 06:51 PM   #8
Mountain Electrician's Avatar
Rewards Points: 238
Probably $60.00
That's the truth!! Motion detectors are my biggest pet peeve...unless you buy a quality one, it's nothing but hassle, hassle, hassle.
Old 02-07-2008, 10:24 PM   #9
okeefe's Avatar
Rewards Points: 25
I agree motion dectors are call back problems, The customers either don't know how to use them or they buy cheap ones that don't do what they thought it would do.
I even leave the instructions with them so they know how to to use it, and they still call as to why the cheapo light is not working, or can I come back and adjust the time or direction of the light.
okeefe is offline   Reply With Quote
Old 02-07-2008, 10:53 PM   #10
Yeah Toast!!
Roger123's Avatar
Well, thanks for all the replies. I'll recommend to purchase a good quality photo cell light.
Old 02-23-2009, 04:52 PM   #11
Default wiring of motion detectors
Want to have a 2 light system of outside lights for a driveway. I would
like to know the simplest way to wire a circuit such that secondary light
is controlled by the primary motion sensing light (which is installed
and working correctly). Problem is that the second light won't ever go off. So
it never loses power. So I'm guessing I need to tie into the power from the primary
sensor and run that to the secondary light?
What is the correct wiring method from 120V input to the primary light
and eventually to the 2nd light so that when the motion
light is activated it allows the second light to activate and more importantly
turn back off.
Thanks in advance for any suggestions.
emc2dn is offline   Reply With Quote
Old 02-23-2009, 05:09 PM   #12
CNC
Rewards Points: 79
to be controlled by the primary motion sensing light (which is installed
and working correctly). Problem is that second light won't every go off. So
it never loses power. So I'm guessing in need to tie the power from the primary
sensor and run that to the second light?
turn back off.
you can take the feed out of the first motion control light, and tie it to the load side of the motion detector.
line volatage comes in, feeds the first motion detector, and the LOAD will feed the lights. The line going to the first light, will also feed the second light, and nuetrals will just be nuetral. The motion detector will have to be rated for the load your applying to it.
CNC is offline   Reply With Quote
Old 02-23-2009, 05:21 PM   #13
Could you explain a bit what you mean by LOAD.
And just be bit more specific about how I wire
and in what order this circuit. Where a solo
sensor light will be activated first, but also
set off a second light without a sensor. And doing
so that all will turn off after timer elapses. Currently
I have my primary motion light working fine. But the
secondary light is split off the main feed and lights
go on but never off. So I thought I would wire
in the second light (without sensor) off the primary
motion dectector.
Old 02-23-2009, 09:26 PM   #14
mattsilkwood's Avatar
Rewards Points: 2,006
turn back off.
i would get a good quality time clockto run the photocell then make the photocell fire an ice cube to make a contactor. rock solid installation, nothing to go wrong.
Old 02-24-2009, 01:01 AM   #15
CNC
Rewards Points: 79
why the relay?
I use time clocks to have an over ride on the photocell, and the photocell switch my lighting loads. But why the relay?
Old 02-24-2009, 01:02 AM   #16
CNC
Rewards Points: 79
motion dectector.
This isnt a DIY forum. I thought you wanted professional advice, not install instructions. hire an electrician.
Old 02-24-2009, 07:38 PM   #17
Originally Posted by CNC View Post
why the relay?
i was being a smart a$$, you dont need the time clock, relay or contactor if the poster couldnt figure out line and load that setup was sure to get a WTF.
Old 02-24-2009, 08:04 PM   #18
ce2two's Avatar
Rewards Points: 690
Post
you should have seen this from a mile away
ce2two is offline   Reply With Quote
Old 02-25-2009, 01:32 AM   #19
CNC
Rewards Points: 79
ok ok, ill work on this
troubleshooting my design? Spat72 Lighting Design 5 03-29-2009 06:47 PM
Troubleshooting GFCI - Residential Shifty Services and Service Equipment 15 12-18-2008 12:15 AM
Recommendation: AC lights off of Inverter, or DC rechargeable lights mhl General Electrical Discussion 4 09-30-2008 07:27 AM
Troubleshooting 5volts General Electrical Discussion 34 06-13-2008 10:12 PM
Troubleshooting Section Roger123 Site Help and Suggestions 1 10-17-2007 05:26 PM
