Underground Fault Locator - Electrician Talk - Professional Electrical Contractors Forum
Old 07-07-2009, 10:57 PM   #1
Rewards Points: 250
Default Underground Fault Locator
In the market for a underground fault locator was just wondering if anyone recommends any brand or if anyone has one that they no longer use. I seem to be leaning towards the 3m one.
Sparky480 is offline   Reply With Quote
Old 07-07-2009, 11:04 PM   #2
drsparky's Avatar
Rewards Points: 276
Get married, wives have no trouble finding all your faults.
Old 07-07-2009, 11:13 PM   #3
Rewards Points: 250
Stay single its WAYYYY easier
Old 07-07-2009, 11:21 PM   #4
Rewards Points: 1,336
Fault Wizard by IUP Corp. It does a nice job. We have one at work ,it is simple to use.
LC
Old 07-07-2009, 11:22 PM   #5
Are you talking about one of the portable type you stick the probes in the ground as you walk along, or is it an actual thumper you are looking into?
Old 07-07-2009, 11:23 PM   #6
Rewards Points: 250
The ones with the sticks The first one is the one we have been looking at http://products3.3m.com/catalog/au/e...er/output_html
Old 07-07-2009, 11:45 PM   #7
I own stock in FotoMat!
Rewards Points: 6,520
Progressive 2003 (now Tempo Electronics) is what I use. Gets me down to ¼" of the actual fault.
Old 07-07-2009, 11:53 PM   #8
Rewards Points: 250
Ballpark number do you know what the one goes for?
Old 07-07-2009, 11:54 PM   #9
kbsparky's Avatar
Rewards Points: 1,000
We have the exact same unit, 480. Pinpoint accuracy IF you are probing direct-bury cable.
Once, we kept getting phantom readings with it, but it was not until after we dug it all up that we discovered why it could not pinpoint the problem:
Seems that someone had sleeved the uf cable in pcv conduit under a patio slab. Well, the fault occurred inside of that conduit, but the
unit could only get us as far as the open end of the pipe. That conduit contained the flash from the short condition, and only at the open end could the unit detect a problem existed.
-KB
Last edited by kbsparky; 07-08-2009 at 12:00 AM. Reason: minor grammatical revision
Old 07-07-2009, 11:57 PM   #10
I got mine off ebay a while back for $300 still in the wrapper. Lists closer to $1000 last I looked.
JTMEYER is offline   Reply With Quote
Old 07-07-2009, 11:59 PM   #11
Rewards Points: 3,855
The 3M Dynatel cable fault locator works pretty much the same way. It's good too.
Old 07-08-2009, 12:03 AM   #12
I think around 7-800 new. I've seen 'em on fleabay for around 450. I got mine for $120.
Old 07-08-2009, 12:03 AM   #13
Rewards Points: 250
Been looking at the 3m Dynatel and really like that. Its alittle pricey but I understand they all are! Just wanted to get a couple other opinions!
Old 07-08-2009, 12:07 AM   #14
The only reason you'd want to spend the extra on the 3M Dynatel is if you also needed to pick up the ping back from the ball markers and spike markers many utilities use over buried splices and buried handhole boxes. If you don't need to do that, spend your money on something cheaper.
Old 07-08-2009, 02:07 AM   #15
Rewards Points: 524
I have one simuair to this one but it is a Amprobe verison that one I got it was from France and it cost me 650€ and it work pretty good so far.
Merci,Marc
Old 07-08-2009, 10:48 AM   #16
That's why I locate the cable first.... to find out the path it takes. Once I know that, finding the fault goes a lot easier. So if you start getting strange readings, you can figure out why such as in your case.
If a direct-bury cable is sleeved under concrete, there's no reason to be able to pinpoint the fault if that's where it is. You can't repair it there. You must splice a new piece in at both ends anyway.
And there's just no sense in trying to locate a fault in conductors in a raceway. There's no repair you can make to them. They need to be replaced entirely.
underground nick General Electrical Discussion 8 06-12-2009 01:49 PM
underground nick General Electrical Discussion 7 06-11-2009 10:09 PM
Buried cable fault locator tool? RomexJockey Tools, Equipment and New Products 11 04-21-2009 04:02 PM
wire locator superelec Tools, Equipment and New Products 2 04-21-2009 01:11 PM
911 locator switch Woodneye General Electrical Discussion 11 12-20-2007 10:41 PM
