Old 06-26-2009, 10:53 PM   #41
Chief Electron Relocator
That image was taken from a episode i saw. It is real
Are you sure? It may look real, and sound real, and even felt real.....
But are you sure it really is real?
Old 06-27-2009, 12:03 PM   #42
Originally Posted by InPhase277 View Post
Now the tune has changed. Whereas before, there was no such thing at all as unbalanced current, now it is a matter of imagination.
Your perceptions are not my problem. I question the relevancy of "unbalanced loads" to single phase, residential users, although they are and always have been relevant to the PUCOs.
None of you have shown an example of a multiwire "balanced load" in residential use and obviously, none of you care to give it any thought.
I don't recall ever mentioning "imagination" in the discussion, but I did mention definition and now, the relevancy of that definition.
So, give me an example of a multiwire "balanced load" in residential use or STFU and just give it some thought.
Not my problem.
Nope, quite a bit of childish snickering, but nothing about "imagination" other than my not being able to "imagine" a "balanced" 120 volt load in residential service.
Old 06-27-2009, 01:39 PM   #43
steelersman's Avatar
You are a strange dude. Why are you arguing about the theory that the neutral carries the unbalanced current? You say that nobody has given an example of a multiwire balanced load. Well let's pretend that none exist, because I can't think of one, so therefore maybe there isn't one unles you intentionaly wire one as in the case of 2 100 watt bulbs as inphase277 mentioned. Well since there aren't any (let's say) then the neutral is always going to carry some current back on it. And it will never reach full ampacity as it can only carry the difference between the 2 (unbalanced) circuits.
Old 06-27-2009, 05:52 PM   #44
Toronto Sparky's Avatar
Unless one circuit is off and the other is at full load.
Never did believe in downsizing neutrals.. (they still do that?)
Last I heard most jobs now spec the main neutral get doubled up. (I think it's due to harmonics in electronic ballasts and stuff)
Old 06-27-2009, 06:37 PM   #45
Waco, nobody is saying that there is such a thing as a balanced load. It is exactly the opposite that we are talking about. Unbalanced loads cause the neutral to carry some current, but the amount of current in the neutral is the DIFFERENCE between the currents in the two hot legs. We are talking theory, and the theory says, and reality proves, that the neutral carries the unbalanced (that is, difference) current. Period. Do the test. Do the test. Do the test.
Old 06-27-2009, 08:26 PM   #46
Ballast are the least of the worries when it comes to harmonics. Having completed 100's of load studies on 480/277 strictly lighting panels I can say HARMONICS are the least of the issue s IN A LIGHTING PANEL. VFD;s. PCs, rectifiers yes.
Brian John
Leesburg, VA
Old 06-27-2009, 08:35 PM   #47
Originally Posted by waco View Post
But, I really don't care. I'm somewhat surprised by the insults. Guess I mistook this for a board of professionals.
Most of us are just electricians instead. Sorry for the confusion.
Carry on...
Old 06-27-2009, 09:19 PM   #48
Waco insults where thrown in your direction? What was stated are facts you are the type of guy that is most likely smart but arrogant and like to stir the sh*t. When you are wrong you ill never admit it. You will throw BS out at everyone then wonder in your own small minded way, why everyone (or some) think you are an arse.
Brian John
Leesburg, VA
Old 06-27-2009, 10:56 PM   #49
When I'm wrong, I will admit it. This discussion wasn't about right and wrong, it was about an oft used expression that has no real relevancy to anything we do in residential wiring. Apparently, the expression is near and ear to many of you, why I sure don't know and sure don't care.
So, let me know when you discover a "unbalanced" 120 volt, single phase load in a residence.
Old 06-27-2009, 11:02 PM   #50
Of course you will. Never doubted it.
Brian John
Leesburg, VA
Old 06-27-2009, 11:03 PM   #51
Unbalanced with what? If it's sharing a neutral with another 120 volt circuit then you bet it will be unalanced in comparison to the other circuit.
Old 06-28-2009, 09:20 AM   #52
I was on a job in a school working 3-11. I was working on fire alarm and 2 other guys were changing panel guts and it was after dark. All of a sudden the lights flashed like a camera flash. I was like what was that and the other guys said i don't know. I looked in this computer room and there was a fire at a surge suppressor, Like a dummy i ran in there and pulled it apart with linemans. I could hear the computers crackling. Turn's out someone years earlier who ran that circuit landed the mwc conductor's in one panel next to the one they were working on and landed the neutral in the panel they were working on. When they were lifting the neutrals. Bam 240 volt across the 2 hot's and that started the fire and blew about 20 computers. wasn't our guys fault took pictures and moved on.
Loose Neutral is online now   Reply With Quote
Old 07-29-2009, 11:13 PM   #53
Default Neutral Current
All of these answers are very good. But can I just ask one question? Why exactly is the unbalanced load returning on the neutral. I am sure that it has everything to do with each "hot" being out of phase with one another. So no phase is fully + at the time of another. But I still feel unclear on the topic. I know what the neutral does, but not why it does it. Could someone please clear my head with as much detail as possible. Thanks
sparky028 is offline   Reply With Quote
Old 07-29-2009, 11:27 PM   #54
Sorry, what is a mwc conductor? Thanks
Old 07-30-2009, 12:19 AM   #55
Default single phase current on neutral conductor
Hello, Waco
I just wanted to see if you can clarify my mind on your previous post. In a single phase system (residential for the most part). You mentioned that the current on the neutral conductor is always balanced no matter what. But what if some home owner used a 14/3 romex cable to feed 2 separate loads but put each hot wire of that cable on the same phase in the panel. My question is would the neural wire then be unbalanced? Thanks J
Old 07-30-2009, 12:36 AM   #56
Originally Posted by sparky028 View Post
Hello, Waco
The current in the neutral would be the sum of the current in each leg. On opposite phases, the currents are equal and opposite, so they cancel, and no current flows on the neutral. If they aren't equal, the difference flows on the neutral.
Old 07-30-2009, 08:13 AM   #57
Please excuse a brief hijack here, but since someone brought it up ealier - could you direct me to info on harmonics? It is one of those areas I would like to understand better.
Thanks
noexpert is offline   Reply With Quote
Old 07-30-2009, 09:50 AM   #58
Thanks
Do a Google Search and any particular questions?
Brian John
Leesburg, VA
Old 07-30-2009, 10:21 AM   #59
Thanks
http://lmgtfy.com/?q=%22harmonic+currents%22
Old 07-30-2009, 05:19 PM   #60
Dogman
Are 5 wire meter loops legal, 3 down to the top meter, 2 up to the consumers side.
dogman is offline   Reply With Quote
Understanding Ballasts, Capacitors, and Igniters petek57 General Electrical Discussion 20 05-29-2009 08:09 PM
Online copy of NEC code/Understanding NEC thekoolcody NEC Code Forum 6 05-08-2009 11:11 PM
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
load calculations Please Help powerline General Electrical Discussion 1 03-04-2009 08:44 PM
understanding union pay nighttrain112 Union Topics 31 07-26-2008 08:35 AM
