Old 04-25-2008, 10:14 AM   #1
Question us voltage
does any1 know wot the normal operating voltage of domestic installs is in the usa?
mtom is offline   Reply With Quote
Old 04-25-2008, 10:21 AM   #2
Not Banned Yet
BryanMD's Avatar
With a (very) few exceptions US residential is 240/120V 60hz 1ph
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
Old 04-25-2008, 10:26 AM   #3
Question
the reason i ask is i am buying a cordless drill from the us and im nt sure if the charger will work over here
Old 04-25-2008, 10:33 AM   #4
Seen your member
Try looking it up at the manufacturer's website. Many chargers are 120/240 volt.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 04-25-2008, 02:03 PM   #5
Knowing where "over here" is would help.
Some "smart" chargers are rated for "110-240v".
Old 04-25-2008, 02:18 PM   #6
Bkessler's Avatar
I am guessing australia
When ls lunch
Old 04-25-2008, 02:45 PM   #7
Not Banned Yet
BryanMD's Avatar
Pete-
the sign up page needs to be changed to require **something** be put in the location window. A minimum of the 2 letters for state or country would do fine.
Old 04-27-2008, 12:20 PM   #8
You better look at the charger specs before you order it. Not only the voltage but the plug. Your plugs are different from ours and so are your receptacles. If the voltage is okay, order our plug and recetacle if possible.
Low Voltage/ High Voltage MikeD NEC Code Forum 18 02-19-2009 05:17 PM
what voltage drill RHarv Tools, Equipment and New Products 22 10-02-2008 05:06 PM
Unbalance voltage Suraj General Electrical Discussion 3 09-28-2008 12:44 PM
Low Voltage/ High Voltage MikeD Structured Wiring 1 07-09-2008 04:49 PM
Line voltage and low voltage makita1 Structured Wiring 1 03-27-2008 07:06 PM
