Using 2 single pole GFCI Breakers - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 04-29-2008, 10:14 PM   #1
Default Using 2 single pole GFCI Breakers
I am installing a pool. Can I use 2 single pole GFCI 20 amp breakers to feed the 220 volt pump instead of a double pole GFCI? If so how does it wire with respect to the neutrals?
Trane Tech is offline
Old 04-29-2008, 10:41 PM   #2
Look, Listen and Live
BackInTheHabit's Avatar
All multi-wire branch circuits must be simultaneousy disconnected as per NEC 2008 210.4
I would ask your local inspector. But I would put it on a 2 pole GFCI. I realize these are more expensive, but don't cut corners.
BackInTheHabit is offline
Old 04-29-2008, 11:46 PM   #3
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,228
I would first question if this install is a MWBC?
Second, two single pole breakers can meet the requirements of 210.4 with a handle tie installed.
If this install is a MWBC then two single pole GFCI breakers will not work. One circuit may at times draw more current then the other circuit and this will cause a current in-balance which can trip the breaker.
Roger123 is offline
Old 04-29-2008, 11:54 PM   #4
Default Mwbc?
What is MWBC? I have a neutral pulled to power a timer. I have already bought 2 single pole GFCI breakers. I guess I did not have to but I did! Can I m ake this work or do I need to get a double pole GFCI? "
Old 04-30-2008, 12:28 AM   #5
Yeah Toast!!
Roger123's Avatar
MWBC is a multi wire branch circuit. Two separate circuits sharing one common neutral.
Now after re-reading this install is for a pool you may be required to have GFCI protection for this circuit. If so, the best install would be a double GFCI breaker as Back-in wrote.
Roger123 is offline
Old 04-30-2008, 05:50 AM   #6
R.I.P. 2014
I guess this is a residential pool with the pump outside. Is a gfci required for this type of hardwired install? As for the neutral for the timer, I would have used a 240v timer and forgot about the neutral.
randomkiller is offline
Old 04-30-2008, 07:10 AM   #7
Speedy Petey's Avatar
Rewards Points: 2,166
Thanks for posting on ElectricianTalk.com. The Moderators/Admin of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
As stated in the sign up page, ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Speedy Petey is online now
Closed Thread
3 pole vs 2 pole faber307 General Electrical Discussion 19 04-28-2010 07:39 AM
Temporary Pole Tribulations alcoelectrical General Electrical Discussion 15 10-11-2008 02:49 PM
Grouting pole bases bigredc222 General Electrical Discussion 2 11-02-2007 06:51 PM
I need a 2 pole 40 GFCI breaker for Challenger Panel 00Funk Services and Service Equipment 5 10-20-2007 04:30 PM
New use for a single pole switch! Joe Tedesco Code Violation Discussion 5 05-20-2007 06:39 AM
