Using non-shunted "tombstones" on a T8 ballast - Electrician Talk - Professional Electrical Contractors Forum
Old 06-29-2009, 09:12 PM   #1
Rewards Points: 2,002
Default Using non-shunted "tombstones" on a T8 ballast
Will this cause premature failure of the lamps and/or ballast? On a few occasions in the past I've used T12 lampholders on a T8 ballast and I did not bridge one side of the lampholder to the other per the ballast diagram. Obviously it still worked, but I'm wondering if this will cause problems down the road.
Old 06-29-2009, 11:24 PM   #2
k2x
Should shorten the lamp life because the start up kick is uneven to one side.
k2x is offline   Reply With Quote
Old 06-30-2009, 02:08 AM   #3
Toronto Sparky's Avatar
Rewards Points: 1,008
Will shorten life.. Seen it. Been there done that. As for why? not sure.
They do make the socket internally jumped.
I'm thinking if you are going to retro you should change the sockets as well.. May even save time an money doing so.
And it's a better job.
Old 06-30-2009, 07:34 AM   #4
Rewards Points: 3,855
When only one lead is connected, the cathode current only travels on one leg of the filament of the cathode instead of parallel on both leads of the cathode. This causes excessive current on one cathode leg and burns it off inside the lamp. This is quite evident with an ohm meter on a failed lamp.
The_Modifier (12-01-2011)
Old 06-30-2009, 06:30 PM   #5
Thanks for the replies. Looks like I have to go back and do some rework. Oh well. Live and learn.
Old 06-30-2009, 06:36 PM   #6
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
Whats the difference between the two sockets?
Old 06-30-2009, 06:44 PM   #7
A shunted socket has both sides of the socket connected together for use with T8 lamps.
Old 06-30-2009, 06:49 PM   #8
child please.....
Rewards Points: 14
Oh ok. I just did 21 fixtures from magnetic to electronic and used the original sockets..i guess, i'll have to wait and see how this works out...i'm kinda nervous now.
Old 06-30-2009, 06:50 PM   #9
If you left the old wires in and cut them off the ballast and spliced onto them with the new wires from the ballast, you should have no trouble at all.
Old 06-30-2009, 06:54 PM   #10
child please.....
Rewards Points: 14
Yeah this is what i did...scared me for a minute.
Old 06-30-2009, 07:05 PM   #11
That's normally how retrofits are done - leave all the old stuff in place and just splice onto it.
In my case, I had to replace some sockets because they had cracked so I just connected the ballast wire directly to the new socket while doing the retrofit.
Old 06-30-2009, 07:34 PM   #12
child please.....
Rewards Points: 14
So, in this case you didn't use a jumper wire...on the new t8 sockets, no jumper is required b/c it internally shunted.
Old 06-30-2009, 08:23 PM   #13
k2x
There are still plenty of t-8 rapid start/ series wired ballasts out there that cannot use a shunted lamp socket. Dimmable t-8's will probably be series wired for a long time.
Old 07-04-2009, 06:05 AM   #14
Rewards Points: 630
It will be nice if they have a marking for shunted tombstone sockets so that way we can able indentify it quick without tearing into the luminaire.
I can't remember who make them and have marking " S " on it but when I was staying in France they have marked " S " or " Shunté " one of the two.
Merci,Marc
Old 07-04-2009, 01:44 PM   #15
All the shunted ones I have seen only have one hole to put the wires.
Well Two.. but they are both on the same side.
Old 11-30-2011, 04:49 PM   #16
I am just not understanding how there is a difference between "shunting" the wires on a T8 instant start ballast & using a shunted socket. I'm trying to retro fit T8 instant start ballast to T8 rapid start ballast. This is the information that I found on the GE website:
Instant Start vs. Rapid Start Sockets
When using programmed start or dimming ballasts in fixtures,
sockets must be 2-pin rapid start type. Fixtures with T8 instant
start ballasts must use jumpered rapid start sockets or shunted
lamp holders (internal to the lamp holder) that bridge the lamp
bi-pins together into one contact on each side of the lamp. If
retrofitting
from a instant start ballast fixture with shunted
sockets to a dimming or programmed start ballast, rapid start
type sockets must be used to properly start lamps and maintain
rated lamp life.
I don't want to shorten lamp or ballast life, but don't understand why it is ok on T12, but not on T8. Thanks for any help.
czr1760 is offline   Reply With Quote
Old 11-30-2011, 08:48 PM   #17
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
not that i care but this thread is VERY OLD
for lunch I had three cans of alphabet soup then afterwards I had a huge vowel movement
ampman is offline   Reply With Quote
Old 11-30-2011, 09:35 PM   #18
crispy critter
green light's Avatar
Rewards Points: 1,024
frenchelectrician,
I recently retroed a lot of lights in a hospital. Some tombstones had to be shunted and some didnt, mostly due to wether the fixture was to be dimmed or not. The shunted tombstones have the letters "shunted" printed right on them. I will try and find one and post a pic.
green light is offline   Reply With Quote
Old 11-30-2011, 09:59 PM   #19
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
But, Its informative
Old 11-30-2011, 10:26 PM   #20
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
retrofitting
rated lamp life.
If you are using T-8 rapid start ballast then the wiring diagram is the same as a T-12 rapid start ballast.
An instant start ballast type T-8 is different and requires the scokets to be shunted.
Welcome to the forum enjoy the show...
CEC question -- running conductors "square" with building lines Animal Other Codes and Standards 7 12-23-2008 03:53 PM
Dont miss "Worlds toughest fixes" tonight! JRent General Electrical Discussion 3 10-02-2008 10:41 AM
New Square D Homeline "old work" load center wirenut1110 Tools, Equipment and New Products 5 07-14-2008 08:09 PM
converting radio volume "dial" to buttons cduluk General Electrical Discussion 7 11-06-2007 08:10 PM
Replace "Potentiometric Null Tester" with Fluke 87 or later model? Joe O'Brien General Electrical Discussion 2 06-28-2007 10:56 AM
