Old 05-31-2011, 08:02 PM   #1
Default Variable speed control making ceiling fans noisy?
I replaced two old 3-speed 5 amp fan controls that controlled 5 ceiling fans each in a small retail store. My supply house ordered me infinitely variable speed switches ( 5 amp Lutron ). The old ones were slide switches with off-lo-med-hi.
Now when the fans are on high they work fine. When you adjust the speed a little lower the fans start to make a humming or slight buzzing sound.
Anyone else had this problem?
Landmark is offline   Reply With Quote
Old 05-31-2011, 08:06 PM   #2
That will always be a problem with variable speed controls. They make the fans hum. I called Lutron and said they are used mostly in commercial applications where noise is not an issue. You need to go back to the selected speed control
Old 05-31-2011, 08:09 PM   #3
Yeah but it isn't a problem, per se. It is the result of the PWM electronics that control the fan speed. The frequency that is used to regulate the motor speed is at the mid to high end of the sound spectrum, so instead of the regular 60 Hz hum, we can hear the higher pitched buzz from the motor. Kinda like a speaker.
Old 05-31-2011, 08:09 PM   #4
Chief Electron Relocator
As Dennis says, those variable speed controls will always have a problem with noise. Get the 3-speed preset models and you'll eliminate 98% of the issue.
Old 05-31-2011, 08:10 PM   #5
Thanks Dennis!
Who makes a 5 amp control like this?
Old 05-31-2011, 08:11 PM   #6
Smoke's Avatar
i came across this long ago, only way i found to fix it was to get the speed control from the fan manufacturer.
there's some technical crap to mull over
Smoke is offline   Reply With Quote
Old 05-31-2011, 08:19 PM   #7
Yes, once.
Don't use variable speed...problem solved.
Old 06-01-2011, 01:05 AM   #8
Just make sure you get dehummed verison they will be little more quiet as well but get in tri speed verison not the vari speed at all.
I found out in hard way many years ago with the ceiling fans.
The cheap ceiling fans tend to be more noisier than well builted fans are.
The most recent one I work on was old school Hunter cast iron ceiling fan that thing you can not really hear it very well pretty quiet { I can able pick up the vibertions when it was running so I know it still running }
Merci,
Marc
ceiling fans! HELP! VinP General Electrical Discussion 28 10-12-2010 10:15 PM
Fan Speed Control crazymurph General Electrical Discussion 1 02-08-2010 11:45 PM
Motor Speed Control Royston PLCs, VFDs, Motors and Controls 7 08-02-2009 01:31 PM
ceiling fans ce2two General Electrical Discussion 16 03-21-2009 12:32 PM
Speed Control Switch for Motor Absolutetruthz General Electrical Discussion 10 05-31-2008 09:29 AM
