Old 11-30-2011, 12:35 PM   #1
A_D
A co-worker of mine was doing wallpack lights about 30' up a wall outdoors. He was looking for a way to hold the lights against the wall with one hand and use the other hand to mark the holes so he could drill them. He decided to use spray paint THROUGH the fixture, onto the wall.
My question is, is he a hack? And what are your thoughts on his method?
A_D is offline   Reply With Quote
Old 11-30-2011, 12:38 PM   #2
Good at being Evil
Shockdoc's Avatar
I guess it works, easier than running a bit through them while holding them.
Old 11-30-2011, 12:40 PM   #3
Aegis's Avatar
Sounds Pro to me.
Aegis is offline   Reply With Quote
Old 11-30-2011, 12:41 PM   #4
I'd make a template out of the box the came in, and use that to mark all my holes. No need to carry each fixture up there to mark.
GDK 13 is offline   Reply With Quote
The Following User Says Thank You to GDK 13 For This Useful Post:
TOOL_5150 (11-30-2011)
Old 11-30-2011, 12:42 PM   #5
A_D
It didn't work, he said it made a huge mess in the fixture, and paint ran down the wall, make the hole mark very big... Hack.
Old 11-30-2011, 12:48 PM   #6
At that point why didn't he just use a sharpie/pencil?
It seems you really aren't cutting out any steps using the spray paint just adding costs and, as you mentioned, unneeded mess.
running dummy is offline   Reply With Quote
Old 11-30-2011, 01:00 PM   #7
Aegis's Avatar
Do they make a sharpie with a 1" end?
Old 11-30-2011, 01:01 PM   #8
I don't quite understand you.
I hold the fixture with my level on it then I trace the outside edge of the hole. Then I put the fixture down and drill in the center of my circles...
Old 11-30-2011, 01:10 PM   #9
A_D
We usually do too. The problem is that these wallpacks are huge, awkward and heavy. And the holes in the fixtures are deep and we cant get a pencil through.
Old 11-30-2011, 01:20 PM   #10
I would just make a template and be done.
Mr Rewire is offline   Reply With Quote
Old 11-30-2011, 01:47 PM   #11
PGW Professional
Magnettica's Avatar
And so would every other electrician with half a brain.
"I have two ceiling fans for you to hang. Should take you only 10 minutes."
--Actual customer
Old 11-30-2011, 01:49 PM   #12
PGW Professional
Magnettica's Avatar
I would also like to suggest making the hole on wall pack larger so if the holes you drill on the wall are not perfect it can easily be corrected.
--Actual customer
Old 11-30-2011, 02:04 PM   #13
Just glue them up with this stuff
joethemechanic is offline   Reply With Quote
Old 11-30-2011, 02:49 PM   #14
A_D
I use that as lube!
Old 11-30-2011, 03:03 PM   #15
Originally Posted by A_D View Post
I use that as lube!
You might end up stuck together like a couple of dogs
Old 11-30-2011, 07:17 PM   #16
B W E's Avatar
Drill a larger hole (big enough for a pencil) an use washers. Makes it easy to level if you screw up drilling.
LED wallpacks mainlug General Electrical Discussion 27 05-10-2011 01:57 PM
3 way switches for 240 volt wallpacks subelect General Electrical Discussion 9 12-08-2010 04:22 AM
spray foam s.kelly General Electrical Discussion 28 06-05-2010 09:01 AM
RAB LED Wallpacks ? Mike Guile General Electrical Discussion 9 04-04-2010 10:01 AM
Spray can pvc cement macmikeman Tools, Equipment and New Products 5 04-07-2009 11:44 AM
