Washer and Dryer on the same receptacle?? - Electrician Talk - Professional Electrical Contractors Forum
Old 10-14-2010, 10:37 PM   #1
Default Washer and Dryer on the same receptacle??
I'm doing work in a house today and i walk through the laundry room and out of the corner of my eye i see the washer and dryer plugged into the same outlet.
The washer and dryer are new LG front loaders and the dryer uses a standard plug. How many amps do these new dryers draw?? I was tempted to pull the dryer out and look at the name plate but i was too busy with other work.
I'm used to washers and dryers being on seperate circuits and 30amp for the dryer.
And i looked for a gas line didnt see it but i didn't look that hard lol Is there a such thing as a dryer that uses a standard plug that is all electric?
pawirenut is offline   Reply With Quote
Old 10-14-2010, 10:39 PM   #2
Click Here
Rewards Points: 2,622
Was it a gas dryer?
Old 10-14-2010, 10:39 PM   #3
rexowner's Avatar
Rewards Points: 508
If it's a gas dryer, no problem.
Sounds like it is if it is plugged into the 120 laundry circuit.
rexowner is offline   Reply With Quote
Old 10-14-2010, 10:40 PM   #4
I'd be hard pressed to imagine those draw enough current to overload a 20 amp circuit, especially if they are the fancy energy star variety.
Resi Sparky is offline   Reply With Quote
Old 10-14-2010, 10:45 PM   #5
Its gotta be gas i'll look tommorow closer just was wondering if there was some new technology for dryers that is so efficient that you can run it on a 15 or 20 amp circuit
Old 10-14-2010, 11:34 PM   #6
220/221's Avatar
Rewards Points: 3,556
Microwave dryer?
I don't think they exist but maybe they should.
Old 10-14-2010, 11:42 PM   #7
Rewards Points: 2,744
Well,I was looking at a setup today for a washer and a gas dryer- one 20 amp circuit on a duplex gfi receptacle outlet. The washer nameplate was 12 amps and the dryer nameplate says 6.2 amps @ 120 volts. Now will the dryer actually pull 6.2 amps running? (I assume spin motor,light, and controls). Maybe, but that is not the point. The point is the two nameplates for 2 fixed in place appliances run more than 80% of the circuit ampacity.
Old 10-14-2010, 11:47 PM   #8
We know that but in the customers mind hey it works so who cares
Old 10-15-2010, 12:17 AM   #9
That Guy
Mr. Sparkle's Avatar
Rewards Points: 2,002
My buddy who is also an EC just failed a finish for this above reason a few months back. The inspector actually looked at the nameplates for two of those fancy Jetson's looking $tackables and just like mac said, more than 80% when tallied up.
When in doubt, 12/3 to all new laundry receptacle circuits from now on.
Old 10-15-2010, 12:51 AM   #10
Rewards Points: 2,336
Most dryers I have seen use at least 2000w.
the washer at least 1000w.
3000w at 120v
thats 25a.
unless ita a 25a outlet,
then its overload.
But it probably works,
so the customer probably doesnt know better.
Some just dont want to know.
All you can do is tell them,
then its there problem.
Old 10-15-2010, 07:47 AM   #11
Rewards Points: 117
Send a message via Yahoo to brichter
IMO it could draw 100% for up to 2:59:59.
brichter is offline   Reply With Quote
Old 10-15-2010, 07:56 AM   #12
Mostly Harmless
Split Bolt's Avatar
Rewards Points: 1,008
I work in a lot of old houses around here. Many times I have noticed the washer and gas dryer plugged into the same receptacle. Then I notice two BX cables going down the basement wall to the washer plug. One home run and the other continues to the kitchen receptacles! I guess this was SOP back in the 1940s and 1950s!? Whenever I point that out to homeowners, they just shrug and tell me they've never had any problems with blown fuses or tripped breakers.
"Golf is a good walk spoiled." -Mark Twain
Split Bolt is offline   Reply With Quote
Old 10-15-2010, 10:10 AM   #13
Rewards Points: 272
I wired a unit that was both a washer and a dryer. It fit under the kitchen cabinet- dryer and washer were both electric. Of course, the two could never be on at the same time and the w/d was very small. All I needed was one 120V 20 amp circuit.
Old 10-15-2010, 11:36 AM   #14
Vintage Sounds's Avatar
Rewards Points: 3,988
Did they also have FPE panels?
Old 10-15-2010, 02:14 PM   #15
I agree with you on that, and was waiting to get called on it. I figured 480 was going to do it first...
Old 10-15-2010, 02:49 PM   #16
Rewards Points: 770
Dude your avatar is too too nice. Very distracting though in a good way.
Electric Dryer wiring??? sparks134 Residential Electrical Forum 36 09-05-2010 05:43 PM
Dryer and Range BIGRED General Electrical Discussion 30 07-11-2010 02:15 AM
dryer help UPDATE charlie Bob General Electrical Discussion 10 02-10-2010 09:52 PM
help with dryer circuit please charlie Bob General Electrical Discussion 31 02-08-2010 07:54 AM
Washer/Dryer Circuit De-rating mferguson NEC Code Forum 4 07-28-2009 05:40 PM
