Old 11-03-2009, 11:00 PM   #21
mattsilkwood's Avatar
I was talking about the 5" pipe. I haven't ran much of it but it was enough for me.
Old 11-03-2009, 11:03 PM   #22
cdnelectrician's Avatar
You mean conduit? hahaha sorry had to throw that in...
Old 11-03-2009, 11:06 PM   #23
Old 11-03-2009, 11:22 PM   #24
Default Five inch pipe
I don't think that I could do it . The last BIG job that I was on was soooo big that they had Five inch pipe for handrails.
Old 11-04-2009, 12:56 AM   #25
I see...never seen that done before.
Neither have I until this job. The only reason why were doing it this way is because the pipe is being run in a arching tunnel, approximently 1/2mile long. By deep threading the pipe were able get just enough "kick"/bend out of the pipe that makes it uniformal to the other conduit ran there 20years ago.(they did exactly the same thing). Not to mention to bend 5" conduit you would have to send it off site to a place that has a bender for it, which our shop does not have. I will take pictures of it and show you guys, its really not as weird as it seems.
Were running 1 mile of 5" rigid, 1 mile of 3" rigid and 1 mile of 2" rigid down this tunnel under a wasterwater treatment plant.
Its a pretty wicked job... I will try to get as many pictures as possible.
qckrun is offline   Reply With Quote
Old 11-04-2009, 01:42 AM   #26
semi-electrician
I've been threading pipe for the last 40+ years, have never heard of "deep threading". You can't close a die down much or you won't be able to get the pipe into the starting side. How does threading correlate to bending? You lost me there. As for getting oil on your arms, I can see the hands and feet but on your arms? I'd try a barrier lotion like this http://www.alibaba.com/product-free/...uid_Glove.html. Post some pics of "deep threading".
Old 11-04-2009, 09:26 AM   #27
Wyome
I don't understand the process of "deep threading". I get the point of why you are doing it though. Does it make up tight? But I don't see how you actually make the threads deeper. Maybe the dies are different when you get that big, but I don't see how to make it happen on the 2-1/2" to 4" head. Like dvr said, if you set the dies down, then it is the pits to get it started.
Old 11-04-2009, 03:45 PM   #28
Robotic Rat
nolabama's Avatar
Originally Posted by qckrun View Post
Deep threading it as in making the grooves alot deeper than normal so when you put the conduit on the rack you can cheat the pipe in the coupling and bend it without actually bending the conduit.
been there done that -after re-reading what he's doing no no i have not done that and would not recommend doing that
the more i learn the less i know
Last edited by nolabama; 11-04-2009 at 03:49 PM. Reason: im not that big of a hack
Old 11-04-2009, 03:56 PM   #29
Master Electrician
rewire's Avatar
Dawn dish washing liquid
rewire is offline   Reply With Quote
Old 11-04-2009, 05:43 PM   #30
I am a RAT.
william1978's Avatar
Please do it sure would help us understanding this deep threading.
Old 11-04-2009, 05:51 PM   #31
Robotic Rat
nolabama's Avatar
i bet he is running the die about 15 or 20 threads down the pipe as opposed to about 10 and pulling a bit at the sleeve with the other pipe to cheat a quarter of an inch or so
Old 11-04-2009, 05:53 PM   #32
I am a RAT.
That is what we call running threads.
Old 11-04-2009, 05:55 PM   #33
Robotic Rat
nolabama's Avatar
you can break the threads doing that - i would not want to cheat something like that - seems like you could do better just wacking the pipe a bit
whoops he's working with 5 inch
Old 11-04-2009, 08:44 PM   #34
bward76's Avatar
I'm sure it's the way it was done years ago but that doesn't make it legal or correct now. It appears that you are cutting the threads a little deeper so that when threaded together the joint is sloppy and your "bend" is actually a crest where the ends of the pipe meet. I don't mean to be a buzz kill but what you are doing is not correct because the conduit is not being installed in the manner it was intended too by the factory or U.L.. I'm sure everyone thinks it's clever but there's no denying IT'S A SHORTCUT. I've ran plenty of 5" and it is way too heavy to be messing around with paper thin threads installed loosely. The unfortunate part is they possibly out bid with someone with the intentions of doing it correctly. Not to sound harsh, but I hate shortcuts. Just my 2 cents.
bward76 is offline   Reply With Quote
Old 11-04-2009, 09:29 PM   #35
we just use slip couplings and weld it no thread oil nessacary
sparky105 is offline   Reply With Quote
Old 11-04-2009, 10:23 PM   #36
IBEW Local 970 Member
sparky970's Avatar
Maybe your company should buy the right bender it they are bidding jobs involving big conduit.
Old 11-04-2009, 10:27 PM   #37
Robotic Rat
nolabama's Avatar
i second that - i really dont like haveing to try to do a job without the right tools or material - it guarantees a $hitty job
Old 11-04-2009, 10:45 PM   #38
hope they are going to put grounds in because I don't think the pipe will meet the code being so loose
Old 11-05-2009, 07:47 AM   #39
drsparky's Avatar
I think he is "deep threading" to make the connection sloppy so he can move it a few degrees. I never heard of doing something so stupid. It is also violating code. How about being a craftsman and do the job correctly.
"Pay attention son, this is for your own good." - Foghorn Leghorn
