what else fits in a siemens panel - Electrician Talk - Professional Electrical Contractors Forum
Old 10-08-2008, 04:41 PM   #1
Default what else fits in a siemens panel
Can anyone tell me if a cutler hammer CH breaker will fit into a siemens panel??? If not what other breaker will work? thanks
jjdrees is offline   Reply With Quote
Old 10-08-2008, 05:00 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Breakers that are listed for use in that panel should be on the panel cover.
Old 10-08-2008, 05:46 PM   #3
You need a Siemens Breaker! Easily obtained at many home centers- Lowes-HD...
handyman78 is offline   Reply With Quote
Old 10-08-2008, 05:57 PM   #4
Rewards Points: 1,000
Different jurisdictions have different rules regarding the breakers to be used in service upgrades. Some want the same name brand in service upgrades while others are okay with any breaker of the right type.
As I recall, Cutler Hammer BR, Homeline, and GE work in a Siemans, but I recommend you use Siemans.
Old 10-08-2008, 06:40 PM   #5
What do you mean by 'same name brand in service upgrades"? If you have an existing C-H panel, you can only upgrade to another C-H?
They may work in a Siemens, but are they listed for use in a Siemens?
Old 10-08-2008, 08:58 PM   #6
kbsparky's Avatar
....They may work in a Siemens, but are they listed for use in a Siemens?
The Cutler-Hammer "CL" breakers are classified for use in a Siemens panel.
I don't think any of them are "listed" except the Siemens brand itself.
Old 10-08-2008, 09:48 PM   #7
I'd have to say there is a big difference between service panels and the breakers used in service panels. What I wrote means some jurisdictions want GE breakers in a new GE panel; Siemens breakers in a new Siemens panel; QO breakers in a new Square D panel; and Homeline breakers in a new Homeline panel.
Others don't care.
At any rate, a Cutler-Hammer CH breaker won't work in a Siemens.
Old 10-08-2008, 11:36 PM   #8
Rewards Points: 3,855
The Murray breakers are 100% identical, and probably roll off the same assembly line. I've drilled apart a Muray and a Siemens breaker, and they're part-for-part exactly the same. BUT> Murray breakers are not rated for in a Siemens panel. The Cutler Hammer type CL (not CH) is the only one on the market right now that is rated to go in the Siemens panel, as far as I know, besides a Siemens breaker. If memory serves, the short-lived T&B breaker line was also rated for use in the Siemens panels.
Old 10-09-2008, 12:38 AM   #9
BIGRED's Avatar
Rewards Points: 1,006
Yo MD, where you been at?
BIGRED is offline   Reply With Quote
Old 10-09-2008, 08:59 AM   #10
I should have included Murray and I agree, I think Murray and Siemens are virtually identical.
Old 10-09-2008, 10:39 PM   #11
3rd Generation
MF Dagger's Avatar
Rewards Points: 1,010
At one point I think on this very forum there was a picture of a murray arc fault breaker in a siemens box straight from the factory.
MF Dagger is offline   Reply With Quote
Old 10-10-2008, 07:08 AM   #12
Thanks for everyones input.
Old 12-22-2008, 05:28 PM   #13
Default Siemens 3 phase panel?
I need to install a breaker temporarily in a 3 phase siemens panel and I don't have complete info on the panel. What I do have is a grainy photo that I took with a cell phone. What I need to do is install a 2 pole breaker to feed a temporary power distro. I've got a 50A dual CH breaker that fits most panels I encounter. Can anyone make out enough from the photo to help direct me?
thanks
chmed is offline   Reply With Quote
Old 12-22-2008, 06:31 PM   #14
kbsparky's Avatar
It's hard to tell, but that looks like a bolt-on panelboard. If that is the case, then no other brand of breaker should "fit" except for the Siemens.
Old 12-22-2008, 06:40 PM   #15
I stopped by a Siemens distributor and told him it was a "P1" panel and he told me that didn't tell him what he needed to know. He pulled out a Cutler Hammer snap in breaker and said that it was a cheap breaker that might fit. I already had the same breaker in my kit so i didn't take it. Because its a 3 phase panel I had concerns that it would require a special breaker. I've spent some time at the Siemens site trying to find documentation. There is a sea of info that has been difficult to wade through. I guess I need to get the complete numbers off the panel and try to call Siemens. Thanks.
Old 12-22-2008, 06:41 PM   #16
Rewards Points: 83
I agree definetly a bolt on, and a 2-pole 50 for that is expensive, plus you probobly won't find it at big box, most likely you need to find a local siemens distributor.
nyerinfl is offline   Reply With Quote
Old 12-22-2008, 06:43 PM   #17
Rewards Points: 83
Originally Posted by chmed View Post
I stopped by a Siemens distributor ...
Have you opened this panel and looked at it? If you go back to the distributor and ask for a 2 pole 50 amp bolt on breaker it should fit.
Old 12-22-2008, 06:55 PM   #18
I didn't take the cover off when I was there. But it looked to me like a simple snap-in affair. And I took a photo that I thought contained the info I needed but later on I found that it wasn't detailed enough to make out all the numbers. What I can make out is: P1C3??L125C?S. The distributor made it sound like there were so many different kinds that there was little chance that we could figure it out.
I unfortunately can't get back to this panel till the day I have to use it.
Thanks
Old 12-22-2008, 07:26 PM   #19
220/221's Avatar
Rewards Points: 3,552
Call somebody at the building and ask them to read the label on an existing breaker or on the sticker. I can't make it out on my screen.
If it's a QP, it's a plug in.
If it's a B something, it's a bolt on.
220/221 is online now   Reply With Quote
Old 12-22-2008, 08:43 PM   #20
I sure hope you find a better distributor than that in you area.
The P1 panel uses bolt-on breakers, so the Siemens 50A 2-pole breaker would be a B250, a 3-pole would be a B350.
Siemens Soft Starter Theory DennisR General Electrical Discussion 16 06-29-2011 10:14 PM
Panel Clearances calimurray NEC Code Forum 10 08-15-2008 12:02 PM
i need help with a 14 ds siemens mag starter mission pools Off Topic (Non Trade) 9 02-14-2008 10:39 PM
A UK panel chrisb271 UK Electrical Forum 18 11-21-2007 06:02 PM
FS- Siemens Sentron Series 600 AMP Circuit Breaker KC_Timbo General Electrical Discussion 1 10-25-2007 06:23 PM
