Old 08-07-2009, 02:24 PM   #1
Default what size junction box?
I have an industrial application where I have to connect 262mcm locomotive wire to copper bus bars in a junction box. It is three phase, 1000v 500A. I am not sure on 1) the size of the junction box to use, and 2) the spacing of the copper bus bars inside. It is a feed thru, coming from a generator going to another panel. Any info or leads would be appreciated.
tavwtby is offline   Reply With Quote
Old 08-07-2009, 04:46 PM   #2
contact a QUALIFIED electrical contractor. you're welcome.
Old 08-07-2009, 05:29 PM   #3
I'm thinking that you don't need a junction box. You're going to be building a genuine cabinet that will require a UL field evaluation or will need to be manufactured in a UL certified panel build shop.
Old 08-07-2009, 05:41 PM   #4
minor hijack; i've installed lots of custom built cabinets/ j-boxes over the years in comm. and ind. settings. i dont recall any of them " u.l. certified ". gotta have the u.l. sticker to be certified ??? just wondering .
Old 08-07-2009, 06:20 PM   #5
I think we all have. Doesn't make it right.
Old 08-07-2009, 08:16 PM   #6
I do not think the NEC requires this to be listed unless it is for a specific location (Wet, classified, etc.)
That said, the AHJ still has to approve it and they do not have to.
Old 08-07-2009, 08:38 PM   #7
Something similiar coming up on my job...
We have 3/0 MI cable coming from a shaft into a box w/copper detail changing over to 500s for a generator feed. We are using a 36 by 36 box about 24 inches deep. Hope this helps!!!!!
Control Freak is offline   Reply With Quote
Yet another buried junction box... MDShunk Code Violation Discussion 16 03-08-2011 03:05 PM
Junction box winter Residential Electrical Forum 1 07-26-2009 06:14 PM
AMP connectors instead of junction box mollydog General Electrical Discussion 22 01-16-2009 06:19 PM
Junction Box wiring Geraldo General Electrical Discussion 4 06-09-2007 04:10 AM
Junction Boxes Geraldo General Electrical Discussion 5 06-08-2007 11:16 AM
