What's the difference - Electrician Talk - Professional Electrical Contractors Forum
Old 07-21-2010, 12:15 AM   #1
vos
vos's Avatar
Rewards Points: 150
Default What's the difference
What is the difference between an journeyman and a master electrician ?
vos is offline   Reply With Quote
Old 07-21-2010, 12:21 AM   #2
I own stock in FotoMat!
Rewards Points: 6,520
In my area, the ability to contract electrical work and obtain permits for the jobs.
Old 07-21-2010, 12:29 AM   #3
Rewards Points: 77
Same here! You can not pull permits in CO unless you have a master license.
Colorado Fatboy is offline   Reply With Quote
Old 07-21-2010, 12:29 AM   #4
220/221's Avatar
Rewards Points: 3,582
Semantics.
I think of journeyman as a union term (after a 4 year apprenticship) but I assume it is used in open shops too (most of the work here is non union).
Master is never ever used here. I assume that some states require an individual to pass a test to obtain a masters licence.
I call myself and my guys electricians.....or idiots.
Old 07-21-2010, 01:26 AM   #5
Bkessler's Avatar
Rewards Points: 2,000
No such thing in ca as a "master electrician", it's only self proclaimed, and makes me laugh. I'll be taking the MI masters exam within the next year.
When ls lunch?
Old 07-21-2010, 05:16 AM   #6
Rewards Points: 968
Kentucky has three electrical license classifications: Journeyman, Master, and Contractor. The "Master" license is essentially a foreman license. A master license requires twice the time in trade as a journeyman. By Kentucky law someone with a master license must be present on any job site where electrical work is in progress. In this state a "master" can not pull a permit, but you can be held accountable if the work under your supervision is not code compliant. To pull a permit you must have a contractor license. If a person is a one man operation, they must have a contractor and a master license in this state.
All three licenses require a test and verifiable experience to initially get the license: 4 years Journeyman, 8 years Master, and CE hours each year. You must renew your license(s) each year.
Old 07-21-2010, 05:19 AM   #7
TheRick's Avatar
Rewards Points: 252
Maine has 3 levels of electrician license other than specialty licenses;
Helper Electrician
Journeyman Electrician
Master Electrician
Journeyman and Master level licenses both require one fulfill educational requirements, as well as proving hours of experience and passing a test.
A Master Electrician can work on their own, direct the work of Journeymen and Helpers and pull permits.
Rick -
Old 07-21-2010, 05:34 AM   #8
Fried Bologna um um good!
jwjrw's Avatar
We have no master license. You can get your Journeymans licence thru the county or take the state test thru the state and become an electrical contractor.
Old 07-21-2010, 05:58 AM   #9
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
4 yrs to test for journeyman
10 years to test for master
Don't know for sure, but I've been told VA's Master test is one of the toughest in the country
Continuing ED every two years
Old 07-21-2010, 06:08 AM   #10
Mike in Canada's Avatar
Here in Ontario, Canada, after you serve your apprenticeship and pass the test to become a journeyman you have to wait three more years to take the masters exam. The journeyman's exam is all about the electrical code, but the masters exam is also about every other code that an electrician needs to worry about, like building codes, fire codes, etc.
Mike
Mike in Canada is offline   Reply With Quote
Old 07-21-2010, 06:33 AM   #11
Rewards Points: 2,050
Here in MA.
A journeyman may pull permits but a Journeyman electrician shall have no more than one apprentice/helper under his or her direct supervision or employ and two or more Journeyman electricians shall not associate as partners or otherwise engage in the business or occupation of installing, repairing or maintaining wires, conduits, apparatus, devices, fixtures, or other appliances used for light, heat, power, fire warning or security system purposes without obtaining the necessary Master electrician license.
Masters can run a bossiness but also need to maintain their J-man card if they still work with tools.
Old 07-21-2010, 06:52 AM   #12
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
I still don't listen to myself.
Life is hard
Old 07-21-2010, 06:54 AM   #13
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,894
Here in Florida, we do not have Journeyman or Master licenses at the State level.
Journeyman and Master licenses are issues on the County level. The County requirements vary slightly.
One example is Miami-Dade County
You have to be able to prove three years in the trade and have W-2s to prove it. There are some exceptions but for the average person, thats what it is. The exam is code and practical knowledge.
The Master exam is a bit different. You must prove that you have worked in the trade as a Journeyman for three years, supervised people, and worked a good % of your time on three phase systems.
The exam is part business, part code, commercial load calculations and part practical knowledge. A County Master Electrician can only pull permits in the county they have their license in. They cannot contract for Fire or Bugler Alarms for some reason.
BTW,
Union apprentices must have a County Journeyman License before they are allowed to graduate and be accepted as an "Inside Wireman". The local union does not recognized a "Master Electrician" classification and therefore the only guys that usually take that exam are looking for inspector jobs or contracting.
Old 07-21-2010, 04:56 PM   #14
Proud Navy Veteran
Greg's Avatar
Rewards Points: 590
BTW,
Wrong answer, Florida does have a statewide Master's license, it is the EC (Certified Master). The ER is the Registered Master which is the county level. An EC is a full unlimited electrical contractor, meaning he can do fire alarm work.
An ER is a county level Master but can work in other counties providing a letter of reciprocity is sent from the issuing county to the county you want to work in and you have to be bonded in that county. It boils down to money.
An EC on the other hand can work in any county all he has to do is register in that county in order to pull permits.
The only problem with an ER is if you took the test in a county that requires a 70% to pass, you are stuck in that county. The rest of the counties that require a 75% to pass you are good to go.
Journeyman is county level only, and can not pull permits, or contract for work.
Innovative can chime in, I think he is an EC.
Memorial Day: All gave some but some gave all.
Take the time to tell a Veteran Thank You, You owe him/her at least that much. After all Freedom is not Free.
Old 07-21-2010, 05:06 PM   #15
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
[quote=mcclary's electrical;25811
Continuing ED every two years[/quote]
No requirement here.. some guys have not bought a code book since they passed their Masters test.
Old 07-21-2010, 05:59 PM   #16
evil bastard
Rewards Points: 746
The continuing ed is kind of a pain, but it's actually a good thing. There were a bunch of guys running around with "combo" electrical, plumbing and hvac licenses that they aquired in the 70's. They were running around bidding all 3 trades and knew very little about any of the three.
Contiinuing ed put a stop to that
Old 07-21-2010, 10:01 PM   #17
Jlarson's Avatar
Rewards Points: 3,054
I think requiring continuing ed. is stupid, not because its a waste of time but because if your a professional that cares about what your doing learning new stuff related to what you do should be something you should do automatically, not be told to.
Just my 2 round things with Abraham Lincoln's picture on them
Old 07-21-2010, 10:14 PM   #18
Semper Fidelis
As you were!!, Wrong Answer!!
Im an EC. In fact, I have 3 separate EC licenses in Florida. None of them say "Certified Master" the only "Master Electrician" license I was ever issued was on the county level. The State of Florida does not have anything titled "Certified master"
Know your facts before you throw it down on the "master"....
Old 07-21-2010, 10:21 PM   #19
Infiltrator
Widestance_Politics's Avatar
Rewards Points: 612
We have Apprentice, Journeyman, and Master in Idaho.....gotta fulfill 8000 hours OTJ training and prove a minimum of 576 hours in class for JW. Master requires that you are a JW for at least four years and pass the exam. Gotta be a Master electrician to become an EC or you must employ at least one Master. Continuing education is required every 3 years.......I think the only requirement for being a "helper" here is to be fluent in any language besides English
If your Sunni you ain't Shi'ite.......
Widestance_Politics is offline   Reply With Quote
Difference between books? qckrun Union Topics 82 09-24-2009 10:53 PM
Difference on Canadian & U.S. licensing personal Off Topic (Non Trade) 13 01-30-2009 10:51 AM
Difference between a PT & CVT speedtronic General Electrical Discussion 1 10-27-2008 06:02 AM
Difference between FVNR & FVR MCC Starter? ms9 General Electrical Discussion 2 06-02-2008 09:42 PM
