Wild leg - Electrician Talk - Professional Electrical Contractors Forum
Old 01-27-2012, 08:41 PM   #1
Clintmiljavac's Avatar
Rewards Points: 154
Default Wild leg
So I have a 3 phase 120/208 service...so I thought, meter is tag that after looking further they changed the utility x-former and I have 120/240 with c phase being 215 volts to ground A n B r about 250 volts phase to phase my question is can u use that wild leg or what's your guys experience with it, I have never came across this
Clintmiljavac is offline   Reply With Quote
Old 01-27-2012, 08:44 PM   #2
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
sounds like a 208 high leg, but it's usually B phase..ur wires marked right?
I'd rather be sleeping.
Old 01-27-2012, 08:46 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Yeah, you can use the wild leg. Just not with a single pole breaker.
Old 01-27-2012, 08:46 PM   #4
Rewards Points: 154
No they were tagged blk red blue in panel and disco I found this out with my meter when checking voltage. Im gonna re-tag Monday
Old 01-27-2012, 08:47 PM   #5
evil bastard
Rewards Points: 746
Around here, It's supposed to be C phase at the meter
Old 01-27-2012, 08:48 PM   #6
BuzzKill's Avatar
poco rules?
Old 01-27-2012, 08:48 PM   #7
Rewards Points: 154
Y not a single pole breaker?
Old 01-27-2012, 08:48 PM   #8
kbsparky's Avatar
Rewards Points: 1,000
I hope you didn't have any 120 Volt loads connected to that leg when they changed up the transformer ...
-KB
Old 01-27-2012, 08:48 PM   #9
BuzzKill's Avatar
ohm out your wires,too
Old 01-27-2012, 08:50 PM   #10
evil bastard
Rewards Points: 746
poco rules?
Yep. C phase at meter, and B phase at service
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
220/221 (02-06-2012), Bulldog1 (01-27-2012)
Old 01-27-2012, 08:51 PM   #11
Rewards Points: 154
Did but they were a multi-tap ballast on lights
Old 01-27-2012, 08:52 PM   #12
sparkie2010's Avatar
Rewards Points: 510
Out in Orlando they use the B phase. South of the state they use Cphase.
Today is a Wonderful DAY!!
http://www.solaristechnology.net
sparkie2010 is offline   Reply With Quote
Old 01-27-2012, 08:53 PM   #13
Rewards Points: 510
Oh yeah
Old 01-27-2012, 08:53 PM   #14
Rewards Points: 154
So should I just not use c phase at all or if it's a 2 pole breaker for a furnace or so it's ok ?
Old 01-27-2012, 08:56 PM   #15
evil bastard
Rewards Points: 746
You need to land it on b phase and identify it purple. Then use it for 2 and 3 polle breakers. No singles on the high leg.
Old 01-27-2012, 09:06 PM   #16
BuzzKill's Avatar
purple? code is orange at panel...right?
Old 01-27-2012, 09:08 PM   #17
Rewards Points: 154
Thanks mcclary. I thought u mark it with orange phase tape, some reason I remember that in the 2005 code book ?
Old 01-27-2012, 09:10 PM   #18
BuzzKill's Avatar
yeah purple is...weird.
Old 01-27-2012, 09:22 PM   #19
evil bastard
Rewards Points: 746
Yeah, I see purple alot here, but the code does say Orange.
Old 01-27-2012, 09:34 PM   #20
Rewards Points: 2,222
Even though your ballasts were multi-tap, you still can't use the wild leg for 1 pole service to them, the phase-to-neutral voltage is invalid, there is no reference to ground in that circuit so that voltage would float with repect to it. Could be 208, could be 215, could be 220. That's why, when you buy a 120/240V 3 phase 4 wire breaker panel, it doesn't allow you to plug in 1 pole breakers onto the high leg, it's potentially dangerous.
Very odd that the PoCo would chage you like that, I think it technically puts you into a code violation if you are still using the 120/208V 3 phase 4 wire panels, because they will not restrict you (or someone later) from attaching a single pole breaker on that high leg.
Re: C phase vs B phase. There is no universal rule for the PoCos, they can connect it to C or B, especially in legacy systems. But the CODE says that you have to connect it at the PANEL to B phase. Only. And mark it orange there. Doesn't matter what the PoCo did going into the meter, that's their business and they are not goverened by the NEC.
animals gone wild wildleg Off Topic (Non Trade) 6 12-02-2011 07:10 AM
Inspectors gone wild BBQ NEC Code Forum 12 05-21-2011 11:10 AM
Wild NEC code articles kielarsp NEC Code Forum 18 01-16-2011 11:54 AM
Wild Card Weekend John Valdes Off Topic (Non Trade) 31 01-09-2011 01:15 PM
Born to be Wild Podagrower General Electrical Discussion 19 08-30-2010 01:36 AM
