Old 05-08-2008, 02:23 PM   #1
Default wire connectors
Is there a limit on amount of conductors in twist on wire connectors ,and is there an Art. that supports this?Thanx in advance for any replies.
stillirnin is offline   Reply With Quote
Old 05-08-2008, 02:25 PM   #2
Isn't it usually listed by the company who makes the product?
DCsparks is offline   Reply With Quote
Old 05-08-2008, 03:07 PM   #3
yes sir! if my pops was her Id a got smack in the head for that one LOL
Old 05-08-2008, 06:16 PM   #4
Ax grinder
raider1's Avatar
Yes, this is a listing issue. 110.3(B) requires that you following the listing instructions of a listed product.
Chris
Old 05-08-2008, 06:22 PM   #5
"A" inside wireman
randomkiller's Avatar
Another case of "you have to read the instructions", or just be smarter than what your dealing with.
"One Nation Under God"
Old 05-08-2008, 10:36 PM   #6
Sparks on Wheels
Mackie's Avatar
http://www.idealindustries.com/media...mbinations.pdf
2 Cor 13:14
Mackie is offline   Reply With Quote
Old 05-09-2008, 05:02 AM   #7
"A" inside wireman
Originally Posted by Mackie View Post
It's pretty sad if an electrician has to look in a chart for a task as mundane as selecting a wire nut.
Old 05-09-2008, 09:22 AM   #8
Thomp's Avatar
yes sir! if my pops was here Id a got smack in the head for that one LOL
ow, yes the family trades smack I remember it well.
Thomp is offline   Reply With Quote
Old 05-09-2008, 12:00 PM   #9
Never thought I was smarter than the manufacturer.
Work'in For That Free Tee . . .
Be Safe Out there
Old 05-09-2008, 04:19 PM   #10
"A" inside wireman
Give yourself some credit old man.
When if ever did you grab a yellow and stop to look at the chart to see if you could put it on 2 #14's ?
Old 05-09-2008, 10:37 PM   #11
Sparks on Wheels
Mackie's Avatar
Hmmm.... 2 #14's... I think I'd reach for an orange - wait, lemmie look at the chart.
Here's the real problem, if two different nuts will work for the situation at hand, then how do you choose between them???
2 Cor 13:14
Old 05-09-2008, 11:27 PM   #12
JohnJ0906's Avatar
Pack up, go home, and ask on ElectricianTalk, of course!
John from Baltimore
"One day at a Time"
Old 05-10-2008, 05:06 AM   #13
Happy as a Goat herd.
Ecopat's Avatar
"Quid non Resolutio"
Ecopat is offline   Reply With Quote
Old 05-10-2008, 12:05 PM   #14
Mountain Electrician's Avatar
As a contractor, I'd pick the cheapest one.
Old 05-10-2008, 12:10 PM   #15
Seen your member
Most here work for someone else, and the boss may be in the habit of buying all sorts of different brands all the time. A tan wire nut made by Brand X may not have the same capability as a tan wire nut made by Brand Y. So you look at the chart to make sure you're in compliance.
Personally, since I work for myself, I use the same brand, so I don't have to waste time.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 05-10-2008, 12:26 PM   #16
"A" inside wireman
I use the ones I think are appropriate for the task at hand and that being said, I have never looked at a chart or failed inspection for using the wrong one. When I started they were all black, so color wasn't an issue.
Old 05-10-2008, 12:50 PM   #17
Realistically, if you install it and it seems to fit and hold well, it's probably okay. If it doesn't really draw up tight, or it barely goes on at all, 9 chances out of 10 you've selected the wrong wire nut. I suppose it's something you develop a feel for over time.
Old 05-10-2008, 03:48 PM   #18
I had to train a guy how to select a wire nut for the job. He was using reds to splice #14 solid to a fixture wire. A little tug and out came the stranded. I agree with MD It's all about feel.
a-bulb is offline   Reply With Quote
Old 05-10-2008, 04:33 PM   #19
"A" inside wireman
Hey MD, good to see you around here. Hope things are good by you.
Old 05-10-2008, 09:50 PM   #20
gilbequick's Avatar
Depends on the wire nut. Sometimes when using the 3M orange and blue nuts it seemed harder to get a good grab on the nut VS using a red Ideal wing nut. The wing nuts seemed to grab quicker and hold better.
Like many things, sometimes it just comes to personal preference.
MC cable and duplex connectors Rikki Other Codes and Standards 45 09-28-2009 08:59 AM
W/P SEU connectors ACusimano General Electrical Discussion 3 08-13-2008 09:38 PM
New wire connectors code? Golden Arc General Electrical Discussion 21 05-17-2008 03:40 AM
Push in connectors itsunclebill General Electrical Discussion 7 07-06-2007 08:42 PM
Blue wire connectors bobelectric Other Codes and Standards 1 03-24-2007 07:46 PM
