Old 10-10-2008, 10:47 PM   #1
Default Wiring Dayton Exhaust Fan Motor
A client has a 1/4 HP Dayton exhaust fan (3XK51F) with a lot of wires coming out: Green, Orange, Brown, Violet, White, Yellow, Black, Red. He wants to run the fan on 120 volts. I know it can be connected to run on 120 V or 240 V. Does anyone know how it should be wired??
czars is offline   Reply With Quote
Old 10-10-2008, 10:52 PM   #2
Seen your member
Lemme guess.... no instructions or wiring diagram.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 10-10-2008, 11:13 PM   #3
kbsparky's Avatar
Grainger's web site is currently down for maintenance, so I can't check there for the instructions ....
Edit to add: The web site is now up, more information and links available in post #6 below.
Old 10-11-2008, 03:28 AM   #4
"Euro" electrician
Here the typical NEMA single phase motor colour:
1 Bleu
2 White
3 Orange
4 Yellow
5 Black
6 NCA [ no colour assigned ]
7 NCA
8 Red
P1 NCA
P2 Brown
Bear in your mind this chart may change a little due they somehow add new colour so If that the case i will make a note of it.
Ok i will try it here.,, But the green and violet is not listed here but you may want to confirmed on the wire itself { useally will have stamped number as well }
For low voltage connection CCW rotation
L1 1,3,8
L2 2,4,5
to reverse the motor roation you will have to swap both #5 and 8 around.
However I do have condersation about the brown wire which it useally normally used with the thermal protector.
I really suggest that you get ahold or look at the motor nameplate for most recent updated connection diagram.
It should be pretty close the same as I say above unless diffrent so please double check it.
Merci,Marc
Old 10-11-2008, 06:16 AM   #5
Smile Wiring Dayton Exhaust Fan Motor
Thanks for the help. I'll uninstall the motor and look for a wiring diagram. Maybe it will match the NEMA standards.
Old 10-11-2008, 06:22 AM   #6
kbsparky's Avatar
That motor is listed as ¼ HP totally enclosed capacitor-start. At least 2 of those leads are intended for connection to the capacitor. The exhaust fan is rated for hazardous locations with 12" aluminum blades:
You can obtain the installation instructions from Grainger.com by clicking here.
Those instructions do not offer the motor connection wiring scheme, however there is a phone number listed there for parts information.
Old 10-11-2008, 12:09 PM   #7
Did you not check your post on the DIY forum?
Old 10-11-2008, 02:02 PM   #8
Smile Wiring a Dayton Exhaust Fan Motor
OK! The problem is solved. I uninstalled the fan and there was wiring information on the side near the bottom of the motor. Here's the information.
For 120 VAC operation, CCW rotation.
Line 1 connect to Violet
Connect Brown, Orange and Red together
Line 2 connect to White, Yellow and Black
For CW rotation, interchange Red and Black
Thanks for the interest.
220/380 VAC Motor chenley General Electrical Discussion 33 09-16-2008 11:02 PM
motor Bkessler NEC Code Forum 14 07-27-2008 08:53 AM
250 hp motor Controls Guy General Electrical Discussion 38 05-02-2008 05:45 AM
dc motor GREGNC General Electrical Discussion 1 12-19-2007 06:44 PM
Harness power from 40 mph exhaust fan tigershark General Electrical Discussion 1 05-06-2007 04:03 PM
