Old 09-04-2009, 11:45 PM   #1
BIGRED's Avatar
Default 1" y
I found this in a house from the 20's. The house was built as fire proof, concrete floors and concrete joist. One panel fed some rigid pipe going thru the deck.
BIGRED is offline   Reply With Quote
Old 09-05-2009, 12:08 AM   #2
I am a RAT.
william1978's Avatar
What was that used for?
Old 09-05-2009, 12:16 AM   #3
I've always called that fitting a "capped ell". The only time I really ever use one is to go around a hard outside corner, like on the exterior of a building. They're still sort of a pain, because you need to crank a little offset in the pipes when you use them like that.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 09-05-2009, 12:22 AM   #4
I am a RAT.
Is that fitting used for electrical work? I just never seen one.
Old 09-05-2009, 12:24 AM   #5
Motor Repair&Control Shop
electro916's Avatar
Ive always known that type of fitting as a Telephone ell.
Anybody ever heard the same and any reason behind it???
"To Alcohol, the cause of, and solution to, all of life's problems."- Homer Simpson
electro916 is offline   Reply With Quote
Old 09-05-2009, 12:25 AM   #6
electro916's Avatar
T&B makes them, I think they refer to them as a 90 deg. ell, its pretty much a compact LB.
Old 09-05-2009, 12:25 AM   #7
I am a RAT.
I sure haven't.
Old 09-05-2009, 12:25 AM   #8
lectric_hand6855's Avatar
Yeah, we call'em pullin' ells or Jake 90's around here.
lectric_hand6855 is offline   Reply With Quote
Old 09-05-2009, 12:28 AM   #9
Yeah, I've heard those capped ells called telephone ells also. My best guess was that they were favored with the phone companies during a period of time to bring underground phone service into a building rather than using an LB or service ell.
Old 09-05-2009, 01:06 AM   #10
the reason they were called " telephone " ells, were because they were used in telephone booths. at least thats what the old geezers told me in the '70's.
paul d. is online now   Reply With Quote
Old 09-05-2009, 09:03 AM   #11
I am a RAT.
Thanks.
Old 09-05-2009, 09:35 AM   #12
Speedy Petey's Avatar
Me too. "Pull ell" is all I have ever known them as, at least the modern kind.
I have come across the screw cap ones a few times. Funny, I have seen them more on ancient 30A-120v services then anything.
I always keep a couple on the truck.
Old 09-05-2009, 09:36 AM   #13
Nice clean up job BTW.
Old 09-05-2009, 10:40 PM   #14
Robotic Rat
nolabama's Avatar
cool wye used em at murphy oil , explosion proof fittings -neet
Old 09-07-2009, 06:39 PM   #15
electricalperson's Avatar
i use things like this on EMT all the time i call them elbows
Old 09-07-2009, 07:54 PM   #16
Boneshaker's Avatar
As old as that may be, they are a very common item. As an earlier post stated we call them pulling L's. We don't use them on a day to day basis, but relatively frequently. Pretty cool to find something that old in that good of shape.
Boneshaker is online now   Reply With Quote
Old 10-25-2009, 08:33 PM   #17
I use capped ells a lot with explosion-proof stuff. Of course, they're listed for the application, but very handy.
Rob
Old 10-25-2009, 09:05 PM   #18
Default 1" y
Always called them JAKE fittings and I don't know "Y".
Old 10-25-2009, 10:58 PM   #19
Funny how different locations call things differently.
To me, a 'Jake' is a screw-in type straight flex fitting.
Rob
Old 10-25-2009, 11:28 PM   #20
jrannis's Avatar
Its a capped Ell.
A telephone Ell looks more like an LB without a cover. We used to see them in 1930s vintage houses used as a tight turn from the meter can into the house.
Monte Python French Taunting
http://www.youtube.com/watch?v=9V7zbWNznbs
jrannis is offline   Reply With Quote
CEC question -- running conductors "square" with building lines Animal Other Codes and Standards 7 12-23-2008 04:53 PM
Dont miss "Worlds toughest fixes" tonight! JRent General Electrical Discussion 3 10-02-2008 11:41 AM
New Square D Homeline "old work" load center wirenut1110 Tools, Equipment and New Products 5 07-14-2008 09:09 PM
Is there a "rule of thumb" for going to a 480V service instead of a 208V? bbaumer General Electrical Discussion 6 04-05-2008 12:12 PM
Replace "Potentiometric Null Tester" with Fluke 87 or later model? Joe O'Brien General Electrical Discussion 2 06-28-2007 11:56 AM
