Old 09-08-2007, 08:44 AM   #1
frank's Avatar
Default Battery Charger
This Battery Charger is from 1896. You plugged it into a ceiling fixture via the bayonet cap mains end. (lamp holder socket - same as Edison screw). The pinch top lamp served as a voltage dropper but if it charged at AC I don't know. If there is a Westinghouse rectifier in the dial case it will have to be small. Anyhow. A nice piece of vintage kit.
Old 09-09-2007, 10:14 PM   #2
Are you sure it is a charger? It looks more like a device to check for a short in something. when the wires are shorted max voltage is across the lamp.
heresrob is offline   Reply With Quote
Old 09-10-2007, 12:00 PM   #3
frank's Avatar
Rob. Here is a close up of the meter dial. RUNBAKEN BATTERY CHARGER
Old 09-10-2007, 08:10 PM   #4
Default interesting made in 1896
I don't think they had diodes as we know them back then. they probably used selenium type (I think I spelled it right).
bob
Old 09-10-2007, 11:40 PM   #5
Runbaken made a thing just like the Fluke non-contact voltage tester a long time ago called a "Testoscope" way back in the 1940's.
http://www.google.com/patents?id=G1x...BAJ&dq=2476115
Old 09-11-2007, 06:42 AM   #6
Default interesting device
But it says you make contact to the metal part. so, its a contact type device. It's just like the ones I used years ago. (30 to be exact).
bob
Forklift charger kbsparky Services and Service Equipment 5 02-17-2009 11:51 PM
battery charger frank Vintage Electrical 4 02-02-2008 11:50 PM
Battery Wiring??? brian_oates33 General Electrical Discussion 3 01-26-2008 10:31 PM
bad battery charger question..help please randomwalk101 General Electrical Discussion 1 07-17-2007 05:37 AM
Battery m.s.j General Electrical Discussion 2 07-09-2007 03:52 AM
