Old 03-28-2009, 10:06 AM   #1
Default Duplex Outlet No box
Box? we don't need no box.
http://lbpinc.com/Howard-duplex-nobox-a.jpg
http://lbpinc.com/Howard-duplex-nobox-b.jpg
Made by Howard MFG Corp in Iowa
fdew is offline   Reply With Quote
Old 03-28-2009, 10:08 AM   #2
Seen your member
I don't get it. You have a loose device that's not hooked up to anything. I see two holes in them for mounting to a box.
Old 03-28-2009, 10:10 AM   #3
I am not sure what you can use these for but there is a back plate that is made that will adapt a cover plate to a standard box. Will that work? Actually it looks like a standard box holes will work.
Alice
Old 03-28-2009, 10:38 AM   #4
The holes are at standard box spacing but there is also a little Bakelite cover that covers the terminations, and holds the metal parts in place.
They were used in a plaster and lath wall with 3 neat little intersecting 1 in dia holes bored in the wall. No box.
Old 03-28-2009, 10:42 AM   #5
kbsparky's Avatar
typical knob-and-tube device. They didn't use boxes in them days.
-KB
Old 03-28-2009, 10:51 AM   #6
Seen your member
The one of the left of the second pix looks like it would be for an antenna outlet, not line voltage.
Old 03-28-2009, 11:06 AM   #7
semi-electrician
That is the same as the device on the right just with the terminal cover still on.
Old 03-28-2009, 11:40 AM   #8
That looks like the forerunner to the very similar mobile home receptacles that they still make and install today.
Old 03-28-2009, 11:52 AM   #9
Seen your member
But I see no way to mount them to a wall surface, save to anchors or toggle bolts. They still look like ordinary covers to me.
Old 03-29-2009, 02:51 AM   #10
The bakelite cover is the box. I'm sure that wood screws held those to the plaster lathe behind the wall.
Old 05-17-2009, 12:22 AM   #11
3rd Generation
MF Dagger's Avatar
Looks like you wood screw them right to the lath
MF Dagger is offline   Reply With Quote
MC cable and duplex connectors Rikki Other Codes and Standards 45 09-28-2009 08:59 AM
Power Outlet OneLittleBoy Residential Electrical Forum 2 03-24-2009 03:45 PM
Putting In outdoor outlet.... thekoolcody General Electrical Discussion 5 10-08-2008 06:44 PM
outlet katessa General Electrical Discussion 13 04-21-2008 08:08 PM
changing 240v outlet chiefdino General Electrical Discussion 1 02-11-2007 12:01 AM
