06-15-2012, 10:48 AM
Swimmer
GE RR3 Relays
I am working in a house with GE RR3 relays used in lighting circuits.
I expected these circuits to be similar to 3-Wire motor start / stop stations.
However, I found that the rocker switch, used with the relay, uses normally open, momentary contacts for both on and off. I expected a normally closed for the off function and a normally open for the on function like in a motor starter.
Does anyone have a drawing of how this is done with 2 momentary, normally open contacts?
I already have wiring diagrams for GE RRX lighting systems but nothing that shows internal wiring of the relay.
Thanks
Elvis is in the building
06-15-2012, 10:57 AM
It is a great old system.
Basically the RR3 is a mechanically held relay, it has a common lead and open and close leads.
A pulse to on the open lead opens it and it stays open until you send a pulse on the close lead.
Go here for tons of info http://www.touchplate.com/standardSupport.php
And here as well .... http://www.gelighting.com/na/busines...fs/tlclvrc.pdf
The Following 3 Users Say Thank You to BBQ For This Useful Post:
06-16-2012, 10:19 PM
Originally Posted by BBQ
Every homeowner that has it, tells me that they hate it and wish they could get rid of it.
06-17-2012, 02:34 AM
They are kinda noisy.
06-17-2012, 04:12 AM
Why?
What is their issue with it?
06-17-2012, 04:14 AM
Around here the relays are in the basement so that is not an issue.
06-17-2012, 04:57 AM
I think many people's issue with it can be summed up by the fact that they can't find anyone competent to work on it if it fails. I've seen many systems that have no reason to have been butchered up the way they have been.
The Following 3 Users Say Thank You to MDShunk For This Useful Post:
06-17-2012, 04:59 AM
That is pretty much what I picture.
02-10-2013, 07:35 PM
The RR3 relay has a center-tapped-coil which moves the armature longitudinally, depending on which end of the coil has been pulsed. The armature is attached to an over-dead-center, berillium copper spring that completes the external circuit in one position and opens it in the other. The relay can be either open or closed, depending on which end of the coil was last pulsed.
More the 40 years ago, while my house was being built, I wired it for low voltage controlled lighting, using RR3 and RR5P relays. These relays were located in several distribution boxes in convenient locations, permitting easy access to change connections between switches and relays. I also used a 24 volt dc power supply to permit the use of steering diodes to add flexibility to the system, something not possible with ac power. The only failure I've ever experienced was a relay zapped with an EMP from a nearby lightening strike. Needless to say, local electricians are impressed but confused. By the way, I was an aerospace engineer with NASA before I retired. moodybob
The Following 2 Users Say Thank You to moodybob For This Useful Post:
03-01-2013, 03:36 PM
GE Low Voltage System Help:
There is a Yahoo Group dedicated to the GE Low Voltage Control system that has members with extensive knowledge about the system. You can visit the group at:
http://groups.yahoo.com/group/gelv/?yguid=99963299
Henry B, Moderator, GELV Group
03-02-2013, 09:29 AM
Swimmer
Originally Posted by Happy31
Thanks Henry, I just joined the group -Ira
03-02-2013, 10:34 AM
Sounds like a neat system, never seen it before, are the relays just latching relays?
03-02-2013, 10:41 AM
Yes and they are now used in more modern lighting controls.
03-02-2013, 12:55 PM
Hello Ira, and welcome to the group. Henry B
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
have a question about relays
fw541c |
14 |
04-29-2011 02:00 PM |
FACP relays..
B4T |
4 |
06-30-2010 08:51 AM |
Wiring Relays
Toledo |
Services and Service Equipment |
3 |
11-26-2009 10:51 AM |
Relays
alselec |
6 |
11-13-2008 08:54 PM |
contactors/relays
Gavin Adams |
23 |
08-29-2008 12:54 PM |
