Green romex ?? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 09-12-2012, 08:11 AM   #21
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
In addition to the green cloth braided jacket romex, there is also green thermoplastic jacketed cable from the 70's made by Phelps-Dodge.
We had cloth covered Romex, many different colors .
Red , Green , Blue , Silver , Gold , Brown , Orange , maybe other colors too.
It was called NMD 3.
Still see some in older houses !
Steven Wright
Old 09-12-2012, 05:27 PM   #22
Chris1971's Avatar
Rewards Points: 230
Originally Posted by Peter D View Post
I've seen in in houses built in the early 60's at which point they began to switch over to plastic sheathed.
Please give us the complete history of romex wire.
2014 NEC code
Old 09-12-2012, 05:28 PM   #23
Rewards Points: 2,002
How about you stop being a tool instead.
Old 09-12-2012, 05:30 PM   #24
Chris1971's Avatar
Rewards Points: 230
At least my not a troll like you.
2014 NEC code
Old 09-12-2012, 05:32 PM   #25
Could you translate that please?
Old 09-12-2012, 05:53 PM   #26
Chris1971's Avatar
Rewards Points: 230
http://en.wikipedia.org/wiki/Troll_(Internet)
I guess I fit that definition.
2014 NEC code
Old 09-12-2012, 05:58 PM   #27
Going_Commando's Avatar
Rewards Points: 292
Gotta love the tar cloth romex. After doing a panel change my hands end up looking like I worked all day in a coal mine. When my Grandfather started in the trade, he installed that stuff brand new.
Never seen lead covered Romex, but have seen lead filled BX. It's what they used for wiring in wet locations. Pretty clever, and beats the hell out of burying romex!
As far as I know, asbestos was only used to insulate wire for high temp installations, such as early recessed cans and for wiring boilers and the like. I may even know how to strip asbestos insulated wire. You don't use a regular pair of strippers, you use your linemans and squeeze around the end of the wire for the length you want to strip. Just crimp around the wire a few times, and the the insulation will twist right off with a nice clean "cut".
Old 09-12-2012, 06:05 PM   #28
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Early 60's, probably a trademark for it being grounded romex, just like Southwire changed it's color to baby blue at the rise of NM-B
Old 09-13-2012, 12:20 AM   #29
Rewards Points: 664
That cable goes back into the late 1960's.
Norcal is online now   Reply With Quote
Old 09-13-2012, 04:16 PM   #30
Rewards Points: 314
I've seen Black, Gray and Green cloth colored Romex before. Would love to see the others.
Briancraig81 is offline   Reply With Quote
Old 09-13-2012, 05:29 PM   #31
wireman64's Avatar
I've seen that
Sometimes I forget where the wires are supposed to go...
wireman64 is offline   Reply With Quote
Old 09-15-2012, 08:31 AM   #32
Alhenry92's Avatar
ah yes, i have the same kind in my house. i forget how the sheathings made, but i have
12-2. Im 90% positive its from late 50s early 60s. I still have the nongrounding type receptacles :S
Alhenry92 is offline   Reply With Quote
Old 09-18-2012, 09:52 PM   #33
InsaneRyder8's Avatar
Oh yeah, spent many, many hours playing with that type of old romex and others on many, many service entrances. Fun stuff. I always had wondered if there was asbestos in any of the old cloth type wire insulation.
InsaneRyder8 is offline   Reply With Quote
Old 09-18-2012, 09:55 PM   #34
Have you ever seen aluminum 12-2 from the 70's?? Now that is fun. Wires all break off or burn off at the outlet, etc.
Old 11-02-2012, 09:06 AM   #35
I've seen it a few times. I ran into lead covered romex only once.
I did some work in a house with leaded romex could you imagine lugging a full 250' roll of that stuff up 3 flights of stairs.
JlaneCTE1 is offline   Reply With Quote
Old 11-02-2012, 01:39 PM   #36
Ty Wrapp's Avatar
Rewards Points: 1,960
My house is originally all 12-2 aluminum, no problemo.
Ty Wrapp is offline   Reply With Quote
Old 11-02-2012, 08:05 PM   #37
Rewards Points: 194
My whole house was wired with that stuff. I've changed a lot of it out over the last few years when adding something new. It has always been in good shape though.
bruce6670 is offline   Reply With Quote
Old 11-02-2012, 08:10 PM   #38
Rewards Points: 194
I saw it one time when I was an apprentice. We were doing a service change and we found one circuit that was aluminum. It was a short run in a garage so we changed it out for free. The JW I was with said it was a hazard and didn't want to leave it. Homeowner was happy.
Old 11-02-2012, 08:18 PM   #39
Tsmil's Avatar
Rewards Points: 508
My last house was wired with 12/2 aluminum. No problems at all. All devices were al/cu compatible and terminations were serviced regularly. Ended up changing it all out because insurance company was no longer going to insure it.
Tsmil is offline   Reply With Quote
Old 11-02-2012, 11:16 PM   #40
My house was built in 56' there was some of that green cloth type in the house previously, that I believe to have been original. There was some green romex as well that was put in around '76 or so but it was plastic, not cloth. Then, there was some green UF as well, I believe it was installed sometime in the late 70's=early 80's.
The green romex had a better ground then the white stuff.
[IMG]http://www.electriciantalk.com/data:image/gif,GIF89a%12%00%12%00%B3%00%00%FF%FF%FF%F7%F7%EF% CC%CC%CC%BD%BE%BD%99%99%99ZYZRUR%00%00%00%FE%01%02 %00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%0 0%00%00%00%00!%F9%04%04%14%00%FF%00%2C%00%00%00%00 %12%00%12%00%00%04X0%C8I%2B%1D8%EB%3D%E4%00%60(%8A %85%17%0AG*%8C%40%19%7C%00J%08%C4%B1%92%H4%43%26z% C76%FE%02%07%C2%89v%F0%7Dz%C3b%C8u%14%82V5%23o%A7% 13%19L%BCY-%25%7D%A6l%DF%D0%F5%C7%02%85%5B%D82%90%CBT%87%D8i7 %88Y%A8%DB%EFx%8B%DE%12%01%00%3B[/IMG]
Green egg Theriot Off Topic (Non Trade) 19 04-01-2012 04:27 PM
Hey From Green Bay WI Pete H Introductions 21 03-05-2012 06:18 AM
Going Green? Free green bag Chris Kennedy Off Topic (Non Trade) 10 04-23-2011 01:26 PM
Green Goo cornishsparks UK Electrical Forum 5 10-16-2008 05:41 PM
